63 Indy Maxx Motor PICS.
#387284
07/26/09 10:10 PM
07/26/09 10:10 PM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
Well we spent the last 2 days finishing up on my 572ci Indy Maxx motor for the 63 Dart.. have some small items to finish..installing the Motor on wednesday and headed to the fab shop for headers.. Oh. as a side note..WISH INDY was there so slap a few of those guys and their shabby work.. missing 2 rocker studs,1 rocker stud nut has no threads, missing 1 valve cover nut and stud, pushrod clearancing Sucked,One headstud was so tight you couldnt get the nut on it,and it was so tight you needed a 12point nut not 6point,Rocker shaft plugs were shoved so far in, you couldnt get the end stud through the hole..Lifter clearancing was also way off on the #1 & 2 in the lifter valley..Open the box with the finished pushrods and found all kinds of item sent to me that i didnt order..would have gladly traded all the 200.00 worth of parts for a complete set of items for the heads and some QC work on these heads..you would think that for 5400.00 the quality would be superior to anything going.. or at least check the clearanes once in a while...
Re: 63 Indy Maxx Motor PICS.
[Re: BILLYJAY]
#387292
07/26/09 10:16 PM
07/26/09 10:16 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Just back that truck up and deliver to 55305. I have a test mule!
The little old lady from Pasadena is back!
[Re: BILLYJAY]
#387298
07/27/09 06:30 PM
07/27/09 06:30 PM
well im hoping for around 875-900hp and 750-800Ft Torque in my little car which should weigh about 2900-3000lbs..
if your engine builder did his homework, you should expect around 935 hp. looks very nice. goodluck.
