Seatback latches 69/70 B body, Pics? #386591
07/26/09 07:15 AM
07/26/09 07:15 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Anybody got a couple pics of the correct seat back latches (front bench only) in a 69 and 70 b body. Are they different? Does it depend on the level of upholstery (doesn't this determine which headrest the car got too?). I have recently looked at two seats, both had different latches (one plastic, one chrome) but both were on the seat back about 2/3 way up from the bottom. One was in a 69 Coronet, one came from a 70 Satellite.
Jt
Yeah, it's hopped up to over 160...
Re: Seatback latches 69/70 B body, Pics? [Re: jt4406] #386592
07/26/09 07:46 AM
07/26/09 07:46 AM
Washington
69440 Offline
69440  Offline
Washington
The buckles for 69 and 70 appear the same, but are not. There are a couple of small details that set a 69 and a 70 buckle apart. If you saw a plastic buckle, with a push button in the center of it, then that was more than likely a deluxe belt, and those were available for the 1970 model year, in any bodied car. Below is a photo of some 1970, standard buckles. I have no pics of any deluxe buckles at this time. 69440
Re: Seatback latches 69/70 B body, Pics? [Re: 69440] #386593
07/26/09 07:55 AM
07/26/09 07:55 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Thanks for the reply, but I was referring to the latch that lets the front seat lean forward so occupants can get in the back seat. Sorry for not being clear.
jt
Re: Seatback latches 69/70 B body, Pics? [Re: jt4406] #386594
07/26/09 09:34 AM
07/26/09 09:34 AM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
68 and 69 are down low, at the bottom of the seat back near the door.
70 is up high on the side of the seat.
At least that is what I think I know after lots of arguements on this with various folks.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Seatback latches 69/70 B body, Pics? [Re: Kowal] #386595
07/26/09 03:09 PM
07/26/09 03:09 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
That's correct, 68/9 are the same and 70 is a one year only deal.
Re: Seatback latches 69/70 B body, Pics? [Re: rrunner] #386596
07/30/09 06:11 AM
07/30/09 06:11 AM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
Thanks guys, anybody got pics (Snoopy?)
BTT
jt
Re: Seatback latches 69/70 B body, Pics? [Re: jt4406] #386597
07/30/09 07:20 AM
07/30/09 07:20 AM
Massachusetts
LYNCHROAD69.5 Offline
Massachusetts
Not the best picture but I have another I will post later with hardware.
Re: Seatback latches 69/70 B body, Pics? [Re: LYNCHROAD69.5] #386598
07/30/09 10:17 AM
07/30/09 10:17 AM
Massachusetts
Massachusetts
This is a better picture showing the hardware (springs and retainier clips). I believe a plastic washer should also be used on each side....service manual shows blowup of this installed. Good luck...I looked for almost a year to find the set shown....got them from a friend who went to a salvage yard (Yikes).
Re: Seatback latches 69/70 B body, Pics? [Re: LYNCHROAD69.5] #386599
07/30/09 09:15 PM
07/30/09 09:15 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
thanks Wayne
jess
