Page 4 of 6 1 2 3 4 5 6
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385984
07/27/09 11:38 PM
07/27/09 11:38 PM
New Jersey Bada Bing
bremotorsports Offline
Linkage #3
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385985
07/27/09 11:39 PM
07/27/09 11:39 PM
Fuel pump mounting. Note mismatched head markings.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385986
07/27/09 11:40 PM
07/27/09 11:40 PM
Idle solenoid mounting bolt.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385987
07/27/09 11:41 PM
07/27/09 11:41 PM
Distributor clamp (copper plated) and bolt ("Lightning strike" variation).
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385988
07/27/09 11:44 PM
07/27/09 11:44 PM
Choke mounting bolts. Mine are the very UNCOMMON blank top bolts.
Enjoy!
Bill Rolik
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385989
07/27/09 11:49 PM
07/27/09 11:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Nice details Bill, thanks for posting. Do you have any other examples (from survivor orange engines?).
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385990
07/27/09 11:55 PM
07/27/09 11:55 PM
ADDED BONUS!
Here is another 71 340 Cuda convertible I have in my registry, equipped just like mine (Same FE5 body color, non-A/C with manual brakes), except this is a 4-speed. It was built one day before mine on 3/30/71.
Bill Rolik
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385991
07/27/09 11:56 PM
07/27/09 11:56 PM
Passenger side.
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385992
07/27/09 11:58 PM
07/27/09 11:58 PM
Driver side.
BR
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385993
07/28/09 12:11 AM
07/28/09 12:11 AM
Scott,
My intake is the "Spring 71" version, with the hump on the runner.
I have been made aware of a local gentleman here in NJ who supposedly has a fairly unabused 71 hardtop, which I am told has an orange engine. I will advise on that in the near future. Also, I believe that there is a gentleman who is a Moparts member, whose name I believe is Morris, who resides in FL. I believe he is an actual original owner of a 71 340 Cuda. Perhaps he will see this and respond.
Other than Bill Sefton's car, of which I had received many photos directly from him a few years ago, there don't seem to be many 71's in any body style that are legitimately untouched, or close to it.
BR
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385994
07/28/09 12:28 AM
07/28/09 12:28 AM
MA
ragtop Offline
ragtop  Offline
MA
Did all 71 340s, not use the right angle oil filter adaptor, or just the blue painted engines not using it?
Same question about the dip stick.
Did all 71 340s, have the black painted dip stick, or just the blue painted engines having the black dip stick?
Thanks. Great info here. I hope this makes it to the archives.
Re: Detailed stock 71 340 engine pics needed [Re: ragtop] #385995
07/28/09 12:47 AM
07/28/09 12:47 AM
The right angle oil filter adapter MAY be an A-Body thing (I had that setup in my 71 340 Duster). Also, 71 E-Body 340 exhaust manifolds and exhaust pipes were different than 70. Additionally, if the distance between the torsion bars is less on an A-Body than on an E-Body, that may play into possible clearance issues as well.
I have an NOS dipstick, and it has a black handle. And as far as I know, all 340's had a black handle, but I would need a bit more research to determine that for sure. I have two local AAR Cuda's to check on!
BR
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #385996
07/28/09 12:57 AM
07/28/09 12:57 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Just spoke with Mike Ross of BEA, he has a 3-30-71 SPD Cuda 340 4 speed, 3:91 rear. Car VIN sequence #342653. It has a door VIN decal 3/71. Car has an original orange engine.
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385997
07/28/09 01:30 AM
07/28/09 01:30 AM
Most interesting!
The car I referenced in the last photos is 342575 (SPD same day, 3/30/71). One correction: It is EV2, not FE5. Sorry for the oversight. But it obviously has a blue engine. Does Mike's car have Windsor or Mound Road engine? Does the right side valve cover have a wire trough? (342575 was sold several years ago. I know who bought it, but he resold it immediately, and I do not know where it is now.)
Another tidbit: In my archive photos, the door sticker on 342575 shows 4-71. My car, built a day later, shows 3-71.
My engine in 344342 (3/31/71) is a Mound Road engine (Code GM on the block).
Chet Greenwood informed me that his convertible, 332846 (3/19/71) originally had a blue engine. I believe he repainted it orange during restoration.
Please excuse the silver paint.
BR
Re: Detailed stock 71 340 engine pics needed [Re: ademon] #385998
07/28/09 07:13 AM
07/28/09 07:13 AM
Myrtle Beach, SC formerly the ...
340wedge Offline
340wedge  Offline
"right angle oil filter adapter MAY be an A-Body thing (I had that setup in my 71 340 Duster"
My 71 Duster is a July 9th build date, blue engine and has the right angle oil adapter.
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #385999
07/28/09 08:58 AM
07/28/09 08:58 AM
Ont, Canada
moparo Offline
moparo  Offline
Ont, Canada
The only touch ups here were:
Redone air cleaner
new battery cables.
other than that nothing else was changed.
The valve covers were the original removed a week after purchase of the car when new they still have the original paint on them. This car is great for the fine details Scott.
performancecarrestorations.com
Re: Detailed stock 71 340 engine pics needed [Re: moparo] #386000
07/28/09 09:48 AM
07/28/09 09:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Redone air cleaner
new battery cables.
moparo,
Don't get me wrong, not picking on your car/engine, it looks fantastic. However that looks like blue paint overspray on the upper rad hose, back of the alternator, assosiated wiring harness, and throttle return spring? If so that isn't original.
Re: Detailed stock 71 340 engine pics needed [Re: moparo] #386001
07/28/09 09:52 AM
07/28/09 09:52 AM
Is it possible to post the photos?
Bill Rolik
Re: Detailed stock 71 340 engine pics needed [Re: bremotorsports] #386002
07/28/09 10:08 AM
07/28/09 10:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bill, the photos in question are of a survivor 1972 340 engine (yellow Duster detailed in a survivor thread here on Moparts) there are a few pics on page 2 of this thread.
*BTW bill, I have'nt gotten anymore info on Mikes 71 Cuda engine yet.
Re: Detailed stock 71 340 engine pics needed [Re: ScottSmith_Harms] #386003
07/28/09 11:03 AM
07/28/09 11:03 AM
Another angle, this is a column shift automatic car SPD first week of October 1970 at the Hamtramck plant
This engine in this picture also appears to have been manipulated a bit. Notice the by pass hose. The paint density is not consistent with the intake port that it is directly connected to. It shows an impossible paint pattern for two pieces that were supposedly painted together. The hose has a thin over spray look to it while the intake is heavily covered. Paint on rubber does not wear off or thin out over time. It would have either flaked or chipped off. The picture of the blue survivor engine that is posted earlier in this thread conveys the correct look that the hose would have exhibited if it was painted on the engine. -Clamps have been changed however.-
