Which Dominator.... #385065
07/24/09 12:34 PM
07/24/09 12:34 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Has an idle system closest to a 4150HP style carb?
8896 or what?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Which Dominator.... [Re: Von] #385066
07/24/09 12:54 PM
07/24/09 12:54 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
The best way to get as close to a 4150 idle circuit and cruise circuit is to have a 2 circuit Dominator carb built....Preferably with Billet metering blocks so the fuel curve can be manipulated and set correct...Also make sure you get the transfer slot set up with screw in bleeds in the main body....This helps out greatly also.......
There is a 2 circuit Dominator that holley offers, its the 8082 and seems to be OK for an out of the box carb.....Jesse @ BIGS!!
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: Which Dominator.... [Re: Von] #385067
07/24/09 03:07 PM
07/24/09 03:07 PM
As far as the closest idle system I don't have a clue on those details, I really like earlier version non HP 9375 1050 dominator for a foot brake single dominator application on BB Mopar engine for drag racing
Re: Which Dominator.... [Re: Cab_Burge] #385068
07/24/09 03:40 PM
07/24/09 03:40 PM
Q
Quicktree Offline
Quicktree  Offline
Q
my 8896-2 out of the box dom will set and idle all day long with out loading up or going rich.
Re: Which Dominator.... [Re: Von] #385069
07/24/09 04:06 PM
07/24/09 04:06 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 8082-3 hp 1050 idles and runs great around town and doesn`t ever load up.
Re: Which Dominator.... [Re: Cab_Burge] #385070
07/24/09 04:11 PM
07/24/09 04:11 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
I had that carb on a car in the mid 90s. It worked great all around.
Decent street manners and low 9s off the footbrake on motor.
Re: Which Dominator.... [Re: jim sciortino] #385071
07/24/09 05:03 PM
07/24/09 05:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
The older 9375 I have has the 2 circuit style 4150 blocks on it and man it sure seems snappy
Gus
64 Plymouth Savoy
Dana 60
Re: Which Dominator.... [Re: Thumperdart] #385072
07/24/09 05:16 PM
07/24/09 05:16 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have no experience w/ Dominators, but remember a tech guy from Crane who also used to work at Holley saying the 8082 HP 1050 was a good choice for a serious street / strip car running one.
