What is the total cfm rating of the 340-6? #385000
07/24/09 11:10 AM
07/24/09 11:10 AM
MA
ragtop Offline OP
ragtop  Offline OP
MA
If this is different from the 440-6, then why? Thanks.
Re: What is the total cfm rating of the 340-6? [Re: ragtop] #385001
07/24/09 11:23 AM
07/24/09 11:23 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
No... advertised dry flow numbers are 350 on center, 500ea on outboards for 1350cfm. Wet flowed they are closer to 980cm (the more true rating) Small blocks have differences in calibrations, like air bleeds and metering blocks, jets, etc IIRC. But basically same same.
Re: What is the total cfm rating of the 340-6? [Re: ragtop] #385002
07/24/09 11:24 AM
07/24/09 11:24 AM
Kentucky
E
ewolfe Offline
ewolfe  Offline
E
Kentucky
Total cfm rating is 1300cfm. 500cfm for the center and 350cfm for each outboard. I'm wrestling with my combo right now...5" of vacuum at idle and 6 a/f screws...makes for a fun tuning experience.
Re: What is the total cfm rating of the 340-6? [Re: moper] #385003
07/24/09 06:39 PM
07/24/09 06:39 PM
AndyF Offline
AndyF  Offline
1350 is the rating when using the 2bbl system. That isn't the same rating system as used for 4bbl carbs so you can't compare it to a Holley 4bbl. I think you divide by the sq root of 2 to get the standard rating.
Re: What is the total cfm rating of the 340-6? [Re: AndyF] #385004
07/24/09 06:52 PM
07/24/09 06:52 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Correct
Re: What is the total cfm rating of the 340-6? [Re: BSB67] #385005
07/24/09 11:34 PM
07/24/09 11:34 PM
dulcich Offline
dulcich  Offline
I think it is square root of new pressure drop divided by old pressure drop, to arrive at the flow at the new pressure drop. Can't really make sense of the formula you guys are discussing above.
-dulcich
Re: What is the total cfm rating of the 340-6? [Re: dulcich] #385006
07/24/09 11:47 PM
07/24/09 11:47 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
In Vizards book, he estimated the max pull through the six pack from a stock 340 equated to about 780 CFM. 440 would be more, but to say the six pack flows 1350 would be correct only in a motor that could pull that. NASCAR 390's flow gobs more than 390 at 9200 RPM, but they are all flowed at a certain benchmark pressure/vacuum.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: What is the total cfm rating of the 340-6? [Re: dulcich] #385007
07/25/09 01:33 AM
07/25/09 01:33 AM
AndyF Offline
AndyF  Offline
Same difference Steve, just a different way to say it. 2bbl carbs are rated at double the pressure drop for 4bbl carbs so you use the sq root of 2 to compare the flow ratings.
1350 cfm in 2bbl rating is roughly the same as a 950 cfm 4bbl. 1350 x .707 = 950
Re: What is the total cfm rating of the 340-6? [Re: AndyF] #385008
07/25/09 08:56 AM
07/25/09 08:56 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Well if 2 bbls are rated at twice the pressure drop of 4 barrels which have double the barrels, shouldn't a 6 pack be rated at even lower pressure drop? Something like 712 cfm??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: What is the total cfm rating of the 340-6? [Re: CJK440] #385009
07/25/09 04:09 PM
07/25/09 04:09 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
yes
