Re: What is the total cfm rating of the 340-6?
[Re: ragtop]
#385001
07/24/09 11:23 AM
07/24/09 11:23 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
No... advertised dry flow numbers are 350 on center, 500ea on outboards for 1350cfm. Wet flowed they are closer to 980cm (the more true rating) Small blocks have differences in calibrations, like air bleeds and metering blocks, jets, etc IIRC. But basically same same.
[Re: AndyF]
#385004
07/24/09 06:52 PM
07/24/09 06:52 PM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
1350 is the rating when using the 2bbl system. That isn't the same rating system as used for 4bbl carbs so you can't compare it to a Holley 4bbl. I think you divide by the sq root of 2 to get the standard rating.
Correct
[Re: dulcich]
#385006
07/24/09 11:47 PM
07/24/09 11:47 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
In Vizards book, he estimated the max pull through the six pack from a stock 340 equated to about 780 CFM. 440 would be more, but to say the six pack flows 1350 would be correct only in a motor that could pull that. NASCAR 390's flow gobs more than 390 at 9200 RPM, but they are all flowed at a certain benchmark pressure/vacuum.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: CJK440]
#385009
07/25/09 04:09 PM
07/25/09 04:09 PM
Posts: 1,261 ILL
mark7171
ILL
