Post deleted by Defbob
[Re: bonefish]
#384885
07/24/09 09:41 AM
07/24/09 09:41 AM
[Re: bonefish]
#384887
07/24/09 10:25 AM
07/24/09 10:25 AM
Re: -1 heads,blower?
#384888
07/24/09 11:45 AM
07/24/09 11:45 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
that would probably only push my barge into the low 10,s??im runnin 11.70,s now with my simple 496.is that a 9.14 with a street pully or could it be over driven for more? id really like to build a dual purpose mill.im not easy on my cars and really dont get into the show stuff.id like to see nines at the strip.and then be able to tone it down for the street.mabey im thinkin wrong but i figered if i had a bigger blower under driven it would run cooler on the sreet.as you have prob.figered out i dont know squat about blowers,just tryin to figerout my best options before i start buyin parts.
[Re: bonefish]
#384889
07/24/09 01:19 PM
07/24/09 01:19 PM
[Re: bonefish]
#384891
07/24/09 01:56 PM
07/24/09 01:56 PM
[Re: bonefish]
#384896
07/24/09 05:51 PM
07/24/09 05:51 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
.my main question is are the 1- heads OTB a good candidate for this application and woul;d a full port job be of any benifit.
as a racer you know porting is always good to go faster.CFM=HP X atmosphere ratio[14psi = 2x HP with the same temp]just a guess but i think it would take 20 CFM porting to lower the boost psi 1 lb and that may be 20*F per lb psi.just trying to giving you things to think about.
