Mancini cooling fams
#384358
07/23/09 03:13 PM
07/23/09 03:13 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Anybody know who makes them for them??
An HHR isnt going to work(to much depth/width)and Mancini has a nice 16 incher they sell for 49 bucks that will do the trick(2300-2600cfm as i recall), that will be a huge upgrade over my bent up current fan.
they had some at the classic and i didnt get one as they sold out, and have them on backorder
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Post deleted by Defbob
[Re: B3422W5]
#384359
07/23/09 04:08 PM
07/23/09 04:08 PM
[Re: B3422W5]
#384361
07/23/09 04:32 PM
07/23/09 04:32 PM
Re: Mancini cooling fams
#384362
07/23/09 04:34 PM
07/23/09 04:34 PM
B3422W5
Portage,michigan
besides what i though were installation issues, i also worry that my bone stock charging system might not handle the amp load of that fan, in spite of how well it would likely work..that mancini unit(while not perfect)only draws 7.5 amps. so i have to think about as well
[Re: B3422W5]
#384363
07/23/09 04:43 PM
07/23/09 04:43 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hook it up with a relay Don... hot line direct from the battery but the coil lead for the relay off of the ignition that way you dont carry any heavy load through your wiring
[Re: MR_P_BODY]
#384364
07/23/09 05:09 PM
07/23/09 05:09 PM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
Hey Don, none of the usual stock style Mopar alternators will cut it with that HHR fan at low rpm....the old alternators have to be running at about 3000 rpm to put out their rated amperage. I tried it, no good even w/a late '70s 70-something-amp alternator. It was fine around 3 grand but running for couple minutes at idle with the fan on, and the battery would be at 10 or 11 volts which makes for some pretty weak spark. Pretty much have to switch to a GM or a Denso alternator if using that fan
Relays are definitely a great idea, I ran two of them in parallel to take some heat off them and would recommend the same, but they don't help at all with the weak stock charging system.
[Re: ZIPPY]
#384365
07/23/09 05:14 PM
07/23/09 05:14 PM
B3422W5
Portage,michigan
Hey Don, none of the usual stock style Mopar alternators will cut it with that HHR fan at low rpm....the old alternators have to be running at about 3000 rpm to put out their rated amperage. I tried it, no good even w/a late '70s 70-something-amp alternator. It was fine around 3 grand but running for couple minutes at idle with the fan on, and the battery would be at 10 volts which makes for some pretty weak spark. I barely made it home a couple times. Pretty much have to switch to a GM or a Denso alternator if using that fan
thanks, super advice..i will just get that 50 buck fan, i think it will do what i need it to do, and hopefully before next season i can figure out a better charging system. If mancini ever gets them back in stock..would love to know where they get them from
