Hi rpm spark retard #383521
07/22/09 08:37 PM
07/22/09 08:37 PM
nc
E
emarine01 Offline OP
E
nc
Why and how does it make more power?
Post deleted by Defbob [Re: emarine01] #383522
07/22/09 08:44 PM
07/22/09 08:44 PM
Re: Hi rpm spark retard #383523
07/22/09 09:01 PM
07/22/09 09:01 PM
nc
E
E
nc
Is this something worth looking deeper into on a 12 to 1 small block with 34* total advance that only turns in the low 7k range?
Post deleted by Defbob [Re: emarine01] #383524
07/22/09 09:05 PM
07/22/09 09:05 PM
Re: Hi rpm spark retard #383525
07/22/09 09:39 PM
07/22/09 09:39 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have asked this question here and YB without any real solid replies.The Holley pro strip ignition system in my junk allows me to change the timing every 500 RPM.There are parameters of retard for nitrous oxide and boost.Someone should do some research on the dyno with more advance in the lower RPM range ramping down to 7500 to 8500 RPM.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Hi rpm spark retard [Re: hemi-itis] #383526
07/22/09 09:52 PM
07/22/09 09:52 PM
nc
E
E
nc
Must be a tuff question cause its very head specific , For my stuff W5s there are not too many shops that mess with them, looks like more trial and error testing
Re: Hi rpm spark retard [Re: emarine01] #383527
07/23/09 09:48 AM
07/23/09 09:48 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
NO.
Re: Hi rpm spark retard [Re: emarine01] #383528
07/23/09 10:00 AM
07/23/09 10:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I was going to try it but never got around to it, I
was going to put a micro switch on my shifter so it
would activate in high gear only then go to a rpm
chip to engage it at that rpm to a retard box,
but never got to it yet.... I only have a 7 AL-2 box
unlike the fancy digital boxes
Re: Hi rpm spark retard [Re: MR_P_BODY] #383529
07/23/09 10:07 AM
07/23/09 10:07 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I've played with it on my 11.2 to one 34 degree 4" stroke smallblock.....never found any conclusive results.
I've taken out from 4 to 10 degrees once I hit high gear, via my Digital 6 plus MSD box.
No real difference in ET or MPH using the switch.
I've even tried launching at like 38 degrees and taking out 4 degrees to get back to my normal 34 degrees total.....no difference on the time slip.
Re: Hi rpm spark retard [Re: LAR_414] #383530
07/23/09 01:51 PM
07/23/09 01:51 PM
nc
E
E
nc
Thankx guys, ya saved me some time and money
Re: Hi rpm spark retard [Re: emarine01] #383531
07/23/09 02:38 PM
07/23/09 02:38 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The biggest gain would likely be from a long piston dwell engine..
Re: Hi rpm spark retard [Re: emarine01] #383532
07/27/09 09:51 PM
07/27/09 09:51 PM
Chicago, IL
blownEFI Offline
blownEFI  Offline
Chicago, IL
"These go to eleven", Nigel Tufnel
Re: Hi rpm spark retard [Re: emarine01] #383533
07/29/09 11:35 AM
07/29/09 11:35 AM
New York
polyspheric Offline
polyspheric  Offline
New York
It doesn't make more power. The spark setting in high remains what it should be - but it allows more advance in the lower gears which may improve your 60.
Boffin Emeritus
Re: Hi rpm spark retard [Re: blownEFI] #383534
07/29/09 11:54 AM
07/29/09 11:54 AM
Nelsonville , Ohio
Duster3105 Offline
Duster3105  Offline
Nelsonville , Ohio
