Raced my 572 finally the 1st time and won #382167
07/21/09 03:21 PM
07/21/09 03:21 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Raced my 572 finally Friday night..Seems like everything was working pretty good just a couple of small bugs to work out.But still somehow managed to pick up a win first night out.
1st time shot had bad tire shake went 4.673
2nd went 4.638
1st rd 4.639
2nd rd 4.639
3rd rd 4.641 killed 2.5 MPH
4th rd 4.645
5th rd 4.612
final rd 4.636
Not should what happened in the semi's but the other guy i was running ran out by 4 and some change.But all my incremental times were the same except E.T. so i just kinda blew it off as a fluke number and it went right back to mormal the last pass.
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382168
07/21/09 03:27 PM
07/21/09 03:27 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
What combo, weight ect?
Re: Raced my 572 finally the 1st time and won [Re: camastomcat] #382169
07/21/09 03:42 PM
07/21/09 03:42 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
2005 4 link cameron dragster 1950lbs
572 4.500 x 4.500 with 572-13 indy heads tunnel ram and 2 750 alky dominators.
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382170
07/21/09 03:47 PM
07/21/09 03:47 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
The valley! I am sure I saw you run. It was a pretty good turnout Friday night.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Raced my 572 finally the 1st time and won [Re: juicedcuda] #382171
07/21/09 04:34 PM
07/21/09 04:34 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
U.S. 60 Friday...That is an old pic from the valley though.
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382172
07/21/09 04:40 PM
07/21/09 04:40 PM
ok
mopdragster Offline
mopdragster  Offline
ok
What gear and tire combo are you running?
Re: Raced my 572 finally the 1st time and won [Re: mopdragster] #382173
07/21/09 05:42 PM
07/21/09 05:42 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
4.10 gear 33.5x16x15s Mickey Thompson
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382174
07/21/09 07:59 PM
07/21/09 07:59 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Get rid of the M/T and put a set of GoodYears or Hoosiers on it. My dragster would not go 60' with the M/T tires it shook so bad,it would bounce the tires like a T/F dragster. Mine is a hardtail dragster, and I am only trying to help save you some trouble with the tires. That is not meant to bash the M/T tires they just don't work on a dragster. Maybe we can help each other out as we get our dragsters going. There are no Mopar powered dragsters around here to share info. with.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382175
07/21/09 09:59 PM
07/21/09 09:59 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I have one, but single dominator on E85. 572 B1 World aluminum block, 15 to 1, Jesel belt drive, rockers, 10" BTE convertor 5200 stall here, 1850 lbs. It runs 7.70@173 in 7200 feet, but I haven't had this deal at sea level yet. 1.10 60 ft, and I would be willing to trade info if it helps you dragster guys. I wonder how much the tunnel ram helps?
Re: Raced my 572 finally the 1st time and won [Re: camastomcat] #382176
07/22/09 07:13 AM
07/22/09 07:13 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
nice job on the win sc!
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382177
07/22/09 08:25 AM
07/22/09 08:25 AM
Arizona
Chris'sBarracuda Offline
Arizona
So he goes out and wins on his first outing, is super consistent, and you advise him to get rid of the tires that he just won on..
Yeah, that makes sense to me..
Chris..
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382178
07/22/09 08:35 AM
07/22/09 08:35 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
The M/T tires are one of the best things i have ever done. The car went 1.043 to 1.048 on all passes except the first where it did shake and went 1.07 60ft but that was the track and by no means the tires.
James Monroe and several guys are running consistant 4.30s and 6.80s on M/T tires week in and week out.
The tunnel ram is only worth a couple hundreths but on alky the consistancy is unreal..It takes a really big air change to change the car.
But i would love to pass on any info i can or get any info that would help from any of my mopar buddies.
Re: Raced my 572 finally the 1st time and won [Re: camastomcat] #382179
07/22/09 08:38 AM
07/22/09 08:38 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
I have one, but single dominator on E85. 572 B1 World aluminum block, 15 to 1, Jesel belt drive, rockers, 10" BTE convertor 5200 stall here, 1850 lbs. It runs [Email]7.70@173[/Email] in 7200 feet, but I haven't had this deal at sea level yet. 1.10 60 ft, and I would be willing to trade info if it helps you dragster guys. I wonder how much the tunnel ram helps?
Looks like way to tight of a convertor...Mine's the TCI pro -x 9 1/2" thats going to 6100 and it could stand to be a little looser but i just dont really want to shift above 7000.
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382180
07/22/09 11:01 AM
07/22/09 11:01 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have a 8" ATI treemaster in mine. ATI set it up for my engine but they said I needed a 9". So mine may be to loose.
After the M/T I over tired the car with some 1490's(if it can't spin em it can't shake em ). I now have the GoodYear 33.5(Pro-Stock) tire with 4:29 gears in the rear-end. I have only made 1 run a few weeks ago with them and it rained. But on that run my air shifter did not shift(out of air,not the first time but it was the last time)but I had a 1.04 60' my best with the 1490's 1.06. I have an elec. shift in dragster now and hope to get some better times this weekend.
M/T tires and Co2 shifters just do not work for me.
But maybe we can all help each other on tune ups other info.
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382181
07/22/09 12:12 PM
07/22/09 12:12 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I know I don't have enough converter stall here, but the problem is when I switch tracks (there aren't any for 400 mile and I'm jealous as hell of you guys in the midwest) the stall is more like 6000 and I am afraid of being too loose with the 4.10 gear at 2200 corrected. How loose have you gone? Also, on a 1/4 mile track, what RPM are you at the top end?
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382182
07/22/09 12:16 PM
07/22/09 12:16 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
How loose and do you folks race 1/4 mile at all? I would like to go a little looser, but I am unsure how much.
Re: Raced my 572 finally the 1st time and won [Re: camastomcat] #382183
07/22/09 12:21 PM
07/22/09 12:21 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Couldnt really say what the 1/4 rpm is cause i havent ran any 1/4 stuff yet. But it was at 7100 at 148.4 in the 1/8th.
This is also as loose as i have been on a convertor flash other than TCI sent me the wrong one once and it went to 7200 and that was not good at all of course behind my 528.
I have another convertor that i ran behind my 528 that would flash at 4900 and the car would run 499 to 5.01 at 144. Switched to a 6100 and car ran 4.78 at 145
Re: Raced my 572 finally the 1st time and won [Re: sc301v] #382184
07/22/09 01:00 PM
07/22/09 01:00 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have not run mine on a 1/4 mile either. ATI said I might could get by on a 1/8 mile track the converter is not locked up at the 1/8 mile. But may not work for a full 1/4 mile. I hope to change converters over the winter. Bu if it keeps breaking parts may not have the $$$$ to change this winter.
Now would be a good time for me to ask which conveter(company and size) is best for the dragster? I have been told by a fellow racer who runs and wins a lot of S/C races. That ATI is one of the best converter's made,but he thinks they don't deal with enough dragsters to set them up like they need to be. He thinks Hughes may be the best for a dragster.
Again not trying to bash anyones parts,this is my 2nd ATI and I brought it for another engine. So they are not to blame for me having the wrong size converter,it was right for the other engine.
But it would be nice to know maybe not who makes the best converter,but who has the best one for the dragsters.
If we can help each other get the right(best) parts the 1st time maybe we all could run better and save a little $$$$$$
Re: Raced my 572 finally the 1st time and won [Re: MRMOPAR622] #382185
07/22/09 01:26 PM
07/22/09 01:26 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
well maybe I can't help you guys much as I have a bbc powered digger but I will say the for the money hughes has been by far the best convertor for my stuff, both doorcar and dragster. I lost very little switching to Goodyear 1022 34.5x17x16 and now prefer it as it solved my redlite wheelie problems and our tracks are so bad will take all the traction I can get.
btw, my convertors usually go 65-6700 on the tb.
Re: Raced my 572 finally the 1st time and won [Re: MegaDart] #382186
07/22/09 02:22 PM
07/22/09 02:22 PM
ok
mopdragster Offline
mopdragster  Offline
ok
My dragster is a 540 b1 tunnel ram with 1 terminator. I haven't made an 1/8 mile run this year and only 3 wide open runs as we do alot of 8.90 racing. But it went 7.68 174mph at 4000 da.
I switched to a hughes 9" at the beginning of the year and have been very happy with it but it is too tight and is at hughes now being loosened from 5900 to 6300. I also run the goodyear 2200 tire and like it very well. I can also get a pretty much unlimited supply of good used p/s takeoffs of these for anybody interested.
