Seats in the 34 Dodge
#381807
07/20/09 10:58 PM
07/20/09 10:58 PM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
I finally have the seats in the 34 Dodge. I wanted them to be adjustable so that made for some extra work but I'm happy with the way they turned out. They are a tight fit, just touching in the middle with about 1/4" clearance on the door sides. They will probably just touch the doors when the door panels are on. Here are a couple of pics. Arno
Re: Seats in the 34 Dodge
[Re: B1arno]
#381810
07/21/09 12:10 PM
07/21/09 12:10 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
What are the seats out of? How wide is your car door to door on the inside?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: B1arno]
#381813
07/21/09 03:50 PM
07/21/09 03:50 PM
AZ_A12_BEE
Dreaming of the 808
I measured my truck, about the same measurement. ![](/ubbthreads/images/graemlins/thumbs.gif) My only concern is they wont recline enough to be in a comfortable position without the seat being too close to the steering wheel.
37 Plymouth PU
[Re: AZ_A12_BEE]
#381814
07/21/09 04:03 PM
07/21/09 04:03 PM
B1arno
Redwood City Ca.
I measured my truck, about the same measurement. My only concern is they wont recline enough to be in a comfortable position without the seat being too close to the steering wheel.
It does look pretty tight in there! You can always stretch the cab. ![](/ubbthreads/images/graemlins/sawzall-smiley.gif) Good luck! Arno
[Re: poorboy]
#381820
07/23/09 07:51 AM
07/23/09 07:51 AM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I have a set of high back buckets in the 36 from a Durango or Dakoto. Fit well in the width and comfortable position. The drivers side is 6 way power.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#381821
07/24/09 01:51 AM
07/24/09 01:51 AM
Posts: 10,653 Freeport IL USA
poorboy
Freeport IL USA
That 36 be a car or a truck? There is more room in a car, even coupes have more seat room then trucks do. Gene
