Seats in the 34 Dodge #381807
07/20/09 10:58 PM
07/20/09 10:58 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I finally have the seats in the 34 Dodge. I wanted them to be adjustable so that made for some extra work but I'm happy with the way they turned out. They are a tight fit, just touching in the middle with about 1/4" clearance on the door sides. They will probably just touch the doors when the door panels are on. Here are a couple of pics.
Arno
Re: Seats in the 34 Dodge [Re: B1arno] #381808
07/20/09 11:00 PM
07/20/09 11:00 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
This is the bracket I made to mount them.
Arno
Re: Seats in the 34 Dodge [Re: B1arno] #381809
07/20/09 11:01 PM
07/20/09 11:01 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I had to modify the floor bracing to mount the brackets.
Arno
Re: Seats in the 34 Dodge [Re: B1arno] #381810
07/21/09 12:10 PM
07/21/09 12:10 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
What are the seats out of? How wide is your car door to door on the inside?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Seats in the 34 Dodge [Re: AZ_A12_BEE] #381811
07/21/09 01:09 PM
07/21/09 01:09 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
The seats are out of a 99 Intrepid. At about the middle of the door,where the front of the seat is widest and approximently where the seats will be with me sitting in it, it is 42" wide.
Arno
Re: Seats in the 34 Dodge [Re: B1arno] #381812
07/21/09 02:23 PM
07/21/09 02:23 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Arno
Thanks, Im gonna measure my 37 truck in a little while.
Re: Seats in the 34 Dodge [Re: B1arno] #381813
07/21/09 03:50 PM
07/21/09 03:50 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I measured my truck, about the same measurement. My only concern is they wont recline enough to be in a comfortable position without the seat being too close to the steering wheel.
Re: Seats in the 34 Dodge [Re: AZ_A12_BEE] #381814
07/21/09 04:03 PM
07/21/09 04:03 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
It does look pretty tight in there! You can always stretch the cab.
Good luck!
Arno
Re: Seats in the 34 Dodge [Re: B1arno] #381815
07/21/09 04:07 PM
07/21/09 04:07 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Good luck!
Arno
The inside of this thing is no bigger than a mid 80s Niisan or Toyota PU.
Re: Seats in the 34 Dodge [Re: AZ_A12_BEE] #381816
07/21/09 08:42 PM
07/21/09 08:42 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I tried putting a set of mid 90s Intrepid seats in a 54 Dodge pickup cab and couldn't get a confortable angle on the seat. It was nearly straight up at 90 degrees, and the 54 cab is a lot longer then your 37. Don't think it will work. Truck cabs are just not long enough to put in seats that are not almost upright unless your real short. Gene
Re: Seats in the 34 Dodge [Re: poorboy] #381817
07/21/09 08:46 PM
07/21/09 08:46 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Thats what I was afaid of. What options do I have?
Re: Seats in the 34 Dodge [Re: AZ_A12_BEE] #381818
07/21/09 09:27 PM
07/21/09 09:27 PM
lisbon,ohio
beesting Offline
Still a member
beesting  Offline
Still a member
lisbon,ohio
the middle seat in a mini van is real close I heard i have bucket seats out of a 90s dodge car in my 38 truck they're to thick, ok for short trips but would'nt want to go to far
Re: Seats in the 34 Dodge [Re: beesting] #381819
07/22/09 10:53 PM
07/22/09 10:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
You need a set of the "cheap" seats for your 37. Something like the plain jane ones from a front drive car like a Lebaron. They don't have much padding so they are thin and narrow. Most have an adjustable back rest position, but expect to have it nearly straight up. In my 50, I have a set of low back ford buckets that the top of the seat fits under the rear window ledge. That let me back up the seat about 4" or 5" giving a much better angle. The bad thing is it puts your head almost against the window, if I ever get rear ended, my head will take out the window. I have also heard the mini van rear bench seats work well. Gene
Re: Seats in the 34 Dodge [Re: poorboy] #381820
07/23/09 07:51 AM
07/23/09 07:51 AM
Lithonia, Ga
3
36PLYM Offline
36PLYM  Offline
Lithonia, Ga
I have a set of high back buckets in the 36 from a Durango or Dakoto. Fit well in the width and comfortable position. The drivers side is 6 way power.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Seats in the 34 Dodge [Re: 36PLYM] #381821
07/24/09 01:51 AM
07/24/09 01:51 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That 36 be a car or a truck? There is more room in a car, even coupes have more seat room then trucks do. Gene
Re: Seats in the 34 Dodge [Re: poorboy] #381822
07/25/09 06:38 AM
07/25/09 06:38 AM
moparx Offline
moparx  Offline
my humpback measures approximately 48" at the door post and 46" in the center of the doors. i'm going to try to use the middle buckets [gray leather] out of my old 95 caravan. they are approximately 20" wide. this gives lots of room for the doors, but since my driveshaft hump will be rather high, i expect some slight mounting problems to crop up. also, since the roof is chopped, i expect i may [probably] have to lose the headrests. the nice thing about my deal is the fact i don't have a back of a cab to interfear with the seatback angle or foot room.
