Intake porting, help me pick one #381274
07/20/09 05:43 PM
07/20/09 05:43 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
looking at having my smallblock Super Victor done this winter and need some good suggestion's on who can do me a good job at a fair and reasonable price.
Re: Intake porting, help me pick one [Re: dartman366] #381275
07/20/09 05:50 PM
07/20/09 05:50 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Bill, I got a and can take care of you for a 12pk reasonable enough
Russ
Re: Intake porting, help me pick one [Re: max_maniac] #381276
07/20/09 06:07 PM
07/20/09 06:07 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Russ
How about a 6 pak and a new pack of blade's for the ?
Re: Intake porting, help me pick one [Re: dartman366] #381277
07/20/09 06:16 PM
07/20/09 06:16 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Try to get up with Vic S/ST3040 he has spent a lot of time grinding on them
Re: Intake porting, help me pick one [Re: dartman366] #381278
07/20/09 07:07 PM
07/20/09 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill I could make it look like this
Re: Intake porting, help me pick one [Re: MR_P_BODY] #381279
07/20/09 07:10 PM
07/20/09 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
then a little bondo and it'll be perfect
Re: Intake porting, help me pick one [Re: MR_P_BODY] #381280
07/20/09 07:35 PM
07/20/09 07:35 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Man I hope you caught the kids that cut up your stuff Mike
Re: Intake porting, help me pick one [Re: MR_P_BODY] #381281
07/20/09 08:18 PM
07/20/09 08:18 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
Re: Intake porting, help me pick one [Re: dartman366] #381282
07/20/09 09:02 PM
07/20/09 09:02 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
anyone ever heard of or had any dealing with Dr J's Performance, seem to be popular with some of the Engine Master guy's.
Re: Intake porting, help me pick one [Re: dartman366] #381283
07/20/09 09:09 PM
07/20/09 09:09 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Yeah......Bryce Mulvey
BTW.......I can't do an intake without, at least one head.
Re: Intake porting, help me pick one [Re: S/ST 3040] #381284
07/20/09 09:17 PM
07/20/09 09:17 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
That would depend on if I have to pull it apart after I do a leakdown this fall, I really don't want to unless it's necessary,,,,,but you never know
Re: Intake porting, help me pick one [Re: dartman366] #381285
07/20/09 10:49 PM
07/20/09 10:49 PM
SoCal
Brian Hafliger Offline
SoCal
Funny you should mention him...
We are re-doing an engine he assembled for a guy a couple of hours away from us.
He used Indy cnc -2 heads, and an Indy intake that Dr. J ported like the above photo's show.
I flowed his head, then added my Indy intake that hasn't been ported yet, then flowed Dr. J's intake, then flowed a new victor intake that I ported for this engine (we are changing things because this engine did not make HP!).
The victor flowed identical to the Indy that Dr. J did up till .500 where it flowed 4 cfm better than the Dr. J indy. The indy intake did start to outflow the victor at .600 but only by 5 cfm. And we are only running .615 lift max, so that is irrelevant.
If you looked at this intake, you would swear that the Indy ported by them, or hell just OOTB would KILL the victor, ported or not...but it didn't!
And lets just say that the porting I did to the victor only took me about 4 hours...We are leaving the intake tract small because the customer wants TQ down low....lots of TQ.
Unless you TEST the things you plan to use, you really just don't know what you have.
Pick a good porter. Infact, pick the best that you can afford!
Brian Hafliger
Re: Intake porting, help me pick one [Re: Brian Hafliger] #381286
07/20/09 11:21 PM
07/20/09 11:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
Brian.....are you going to be able to do any before/after dyno
pulls or are you having to re-do other stuff too?
Re: Intake porting, help me pick one [Re: S/ST 3040] #381287
07/21/09 12:06 AM
07/21/09 12:06 AM
SoCal
SoCal
No real need to. He dyno'd it at Westech a couple of months ago. He supplied me with the dyno sheets, and all the build info.
Let me say this: whoever did the machine work should stay away from engines!!
This engine has dyno time only, and after we took it apart, we found some really crappy machine work and assembly detail (or lack of).
The bores were so out of round and tapered the skirts of the pistons (which are brand new)looked like the engine had been run dirt track and overheated mulitple times!!
I have a list of things that were wrong, damaged, done improperly, etc...
Just changing out the Indy intake valves for Ferrea gained considerable (around 30)cfm and picked up the velocity in the ports.
They used head studs which located the head incorrectly and when they tightened the head down, it gouged both dowel holes in the head, pulling the head off to one side! On both sides of the engine!!!!!
I will be dynoing the engine after we're done, and I'll post pics and some info.
I know this sounds alot like a bash, sorry for that. But I can't believe the things that were wrong.
I guess even magazines can't make you good!!
Brian Hafliger
