Motor and Trans coming out...................... #381204
07/20/09 04:44 PM
07/20/09 04:44 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Almost ready to pull the motor and trans out of the 65'
I bought a CRT trans last year, ,,and it's been sitting in the garage, ,,waiting to be installed. Doing it now,,,to have the car ready for Norwalk and Monster Mopar in Sept...
The current trans has not been out of the car/freshend in at least 5 years ??...
Had the convertor done with TA last year....
Had the front end, K frame, tubular work done last month with BondoBob,,,so hoping it will be easy just to pull the trans and motor together,,,and re-install,,,,have lots more room as far as pan clearance now....previously i could never pull them together due to the tight clearance with the K frame....
Is there a specific lock tite "color" stength to use on the convertor bolts when i re-install ??
Also wondering if the car will "pick up" any with a fresh CRT tranny ?
Man did my plugs look a bit rough,,,hadnt changed them since last year,,,they were a bit tough to remove from the Eddy heads,,,( i usually put anti-sieze on them ),,,,
Also going to re-do the Caltrac's,,,i ordered a new bushing kit,,,,the front eye(s) on mine are not right,,,wrong spacer in there now,,,with lots of binding ,,, so i ordered the correct size spacer,,to free things up..current 60' are 1.41-1.43,,,, maybe this will improve as well with the Caltrac changes....
572 INDY motor coming next year,,,,hope to run the NSS class someday..............
Have everything unhooked,,,,just have to drain the tranny fluid,,,drop the cross member,,,,and pull the motor and trans....
Doug
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381205
07/20/09 05:09 PM
07/20/09 05:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Doug, I alway's use loctite 272, it's for a higher temp and good for fasteners up to 1.50" dia, 271 will work but I like he higher temp better, both are red in color.
Re: Motor and Trans coming out...................... [Re: dartman366] #381206
07/20/09 07:25 PM
07/20/09 07:25 PM
TN
65racer Offline
2009 IHRA World Champion
65racer  Offline
TN
Doug,
You must like to do a lot of work, I would never pull the engine for a tranny swap, unless there was something I was going to check in the engine,
just unbolt the trans, pull the headers, and drop that baby out, slip the new one in it's place and bolt it back together.
I got a wild hair a couple years ago, I was going to freshen a tranny myself, and see if I could get it to work, never had done one before, the one in my car had been in it for 12 seasons, and had around 2000 runs on it, believe it or not, just regular oil changes, and a band adj, ever so often, I just knew it had to be worn slap dab out, so I did the swap, everything was good, I finally got around to busting the other one open to freshen it up for a spare, and the clutches still had the writing on them, steels looked as new as the ones I had for the freshen up, bands were in great shape, it really didn't need anything done to it, maybe I was just lucky, but I went ahead and freshened it up anyway for a spare.
Maybe your's will still be good, and slip it back for a spare, as far as performance, I didn't see a nickels worth of difference between either of mine.
Good luck, maybe it'll make your car come around, I have always wanted to have one of those professional built jobs, but could never make myself pay the coins, they cost, I'm just plain tight.
Re: Motor and Trans coming out...................... [Re: 65racer] #381207
07/20/09 07:34 PM
07/20/09 07:34 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Doug you can pull the trans out of the 65 with out pulling the engine. I pulled it out one year three times and you do not have to pull the headers to get the trans out. I think you are just getting practice for next year when you put the 572 in.lol but best of luck to you doug. I would like to take your old trans apart just to see how it looks inside. Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381208
07/20/09 07:37 PM
07/20/09 07:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug, invest in one of those engine levelers for
pulling the engine and trans together, with the carb
plate like you have its alot more work and man handling
Re: Motor and Trans coming out...................... [Re: MR_P_BODY] #381209
07/20/09 08:24 PM
07/20/09 08:24 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
X2. You'll never want to be without one once you use one.
Re: Motor and Trans coming out...................... [Re: dartman366] #381210
07/20/09 08:36 PM
07/20/09 08:36 PM
KENTUCKY
KENTUCKY
Dartman,,,thanks for the info on the loctite,,,,cant remember what i used last time,,,but will try the one you recomended....
Doug,
I have had the trans out of the car about 3 times since owning it,,,usually just drop it from underneath,,with the wife adjusting the jack stands,,,lol
I wanted to do some other stuff with the motor while i had it out...and wanted to see if the motor/trans combo would clear the new K frame,,etc,,,plus i got some time before Norwalk,,,,lol
yup,,,that's how i did it before,,,when i did the convertor swap,,etc,,,I still wonder about the front drum in the existing trans grenading,,,so i want to get the CRT trans in,,,,and maybe send the "old" one out for a re-do,,and keep it as a spare,,,,
Mike and Hot,,,i have a engine leveler i bought from Harbor Freight,,,they are local here in Louisville,,,,,should be pretty smooth......
thanks guys,,,,,,,,
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381211
07/20/09 09:37 PM
07/20/09 09:37 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
An engine leveler is priceless, and I have always pulled the engine/trans together to get to the transmission...I don't have a lift, and working under the truck makes me nervous. Nothing like a little earthquake to ruin your day.
Make sure to clean the bajessus out of the threads with brake cleaner or eq before applying any loctite.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381212
07/20/09 10:08 PM
07/20/09 10:08 PM
mopar65 Offline
mopar65  Offline
I don't blame you Doug i think you are going fast enough now to need the billet drum. so what are you going to do to to the engine or is it a trade secret? lol. Bobby
Re: Motor and Trans coming out...................... [Re: mopar65] #381213
07/21/09 06:37 PM
07/21/09 06:37 PM
KENTUCKY
KENTUCKY
Bobby,
Yup,,,I had John (CRT) look at what i needed for the car,,,and the new trans has the billet drum, RMVB, etc...
No major plans for the motor,,,wanted to clean it up a bit,,also curious to see how easy it will be to pull the motor and trans together with the new K frame clearance.
Thanks for the info on the covertor bolts,,,
I am also without a hoist,,and usually have to do this on the garage floor,,,jack stands, floor jack, 2x4, wife assisted,,etc,,, I dont think it will take me much longer to pull the entire thing out.....
thanks guys,,,,,,
Doug
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381214
07/21/09 08:22 PM
07/21/09 08:22 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
Doug if you would like to borrow my hoist, I am right in jtown. Come and get it.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: Motor and Trans coming out...................... [Re: juicedcuda] #381215
07/21/09 08:40 PM
07/21/09 08:40 PM
KENTUCKY
KENTUCKY
Thanks Josh,,very kind to offer.
I should be ok,,, i have a hoist,,,and engine stand,,,
how is your car coming along ?
Re: Motor and Trans coming out...................... [Re: 69CHARGERMD] #381216
07/21/09 09:47 PM
07/21/09 09:47 PM
KY
juicedcuda Offline
juicedcuda  Offline
KY
Motor is in, just waiting on offset lifters and pushrods. Shouldn't be too long. I would like to see yours at the valley when you get it back together. Let me know if you need any help.
Re: Motor and Trans coming out...................... [Re: juicedcuda] #381217
07/21/09 09:55 PM
07/21/09 09:55 PM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
Sounds like a lot of work and hassle.... just sell me the '65 and save yourself all the worry!
Re: Motor and Trans coming out...................... [Re: 300by500] #381218
07/28/09 07:37 PM
07/28/09 07:37 PM
KENTUCKY
KENTUCKY
Everything is out......
also pulled the grill to clean it up a bit....
Need to fix the Caltracs as well...
Should be back together soon......
