Clutch clatter #380661
07/20/09 06:51 AM
07/20/09 06:51 AM
Hunt Valley, Maryland
1fastrunner Offline OP
Hi,
Can anyone tell me what causes the clutch to clatter and shake the car when starting to move in 1st? It's a new clutch and it didn't do it in the beginning.
Thanks,
Re: Clutch clatter [Re: 1fastrunner] #380662
07/20/09 11:24 AM
07/20/09 11:24 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Hi,
Thanks,
I'm sure you know, the clutch needs to be broken it easy, so no hard thrashing for the 1st.4-500 miles, alot of city driveing (stop & go) seats them quicker, other issues could be oil getting on the disc. What type/brand of clutch did you get, & did you re-place or re-surface the flywheel?
Clutch chatter is not a good sign, but its common on a ceramic style disc.
I would drive it some more in stop & go traffic, maybe its still trying to seat.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Clutch clatter [Re: joedust451] #380663
07/20/09 11:54 AM
07/20/09 11:54 AM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
I go along with the oil or other contamination (on the pressure plate/ disc/ flywheel) theory.
Re: Clutch clatter [Re: Kudakidd] #380664
07/20/09 12:25 PM
07/20/09 12:25 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ill agree did you have the flywheel refaced?Saw too many that werent that chattered.Rocky
Chrysler Firepower
Re: Clutch clatter [Re: therocks] #380665
07/20/09 02:20 PM
07/20/09 02:20 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Agree resurface the flywheel
Re: Clutch clatter [Re: joedust451] #380666
07/20/09 03:34 PM
07/20/09 03:34 PM
ky.
K
kenworth_goose Offline
K
ky.
Hi,
Thanks,
Clutchs don't need to be broken in! Oldest wives tale ever. If it has chatter or shakes when taking off look at your mounts, if they are good, replace it again. the springs in the clutch are lose.
Re: Clutch clatter [Re: kenworth_goose] #380667
07/20/09 06:13 PM
07/20/09 06:13 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Hi,
Thanks,
I whole heartily disagree, if you think the surfaces don't need to seat properly, thats your opinion, i know the FACTS, if you don't beleive it, ask ANY clutch manufacture in the country on your theory (or wives tail) & you'll be lauched at, i'll take there word on it!!
Re: Clutch clatter [Re: joedust451] #380668
07/20/09 06:38 PM
07/20/09 06:38 PM
Let me give you some information:
It's a new McLeod clutch set up with a resurfaced flywheel. It didn't shake in the beginning, but started to over time. At this time, I also realized that the pedal was getting closer to the floor to disengage. We noticed that the adjustment had worked it's way down to this point. We readjusted it, and it wasn't as apparent. Driving home from Syracuse, it progressively got worse again as the adjustment again moved.
I'm not sure if this is part of the problem or not, but I think it's a possibility.
As for the adjustment not staying where we set it, how can I remedy that.
Thanks,
Re: Clutch clatter [Re: 1fastrunner] #380669
07/20/09 06:47 PM
07/20/09 06:47 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My last McCleod PP kept losing adjustment.Every time I launched it would have to be readjusted.Installed my CF Dual and adjusted it once after install.That was 2 years ago.Rocky
Chrysler Firepower
Re: Clutch clatter [Re: therocks] #380670
07/20/09 07:42 PM
07/20/09 07:42 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I like CF clutches too.
Re: Clutch clatter [Re: therocks] #380671
07/20/09 07:47 PM
07/20/09 07:47 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Here's a long shot...Check the bolts in the bellhousing. My bro had an old Chebby years ago and when he disengaged the clutch the bell would separate from the engine. He re-torqued the bolts and all was well.
Re: Clutch clatter [Re: 1fastrunner] #380672
07/21/09 09:42 AM
07/21/09 09:42 AM
A Banana Republic near you.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
Double nut the adjustemnt nut , it's probably not locking anymore . driving it with the adjustment changing over that many miles MAY have slightly glazed the flywheel and PP because the clutch was not fully disengaging .
Re: Clutch clatter [Re: JohnRR] #380673
07/21/09 01:09 PM
07/21/09 01:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Check to make sure the clutch cross shaft arm is not bending. Clutch break-in = fantasy tale!
Fastest 300
Re: Clutch clatter [Re: Crizila] #380674
07/21/09 01:15 PM
07/21/09 01:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I drove my CF for maybe 30 miles before I used it hard.Then only a few times.Clutches are like brake.Install new brakes and rotors and pound them.They will glaze and if they dont they wont stop as good as a set that was seasoned easy.Been doing it too long to not know that.Rocky
Chrysler Firepower
Re: Clutch clatter [Re: Crizila] #380675
07/21/09 02:41 PM
07/21/09 02:41 PM
Kudakidd Offline
Kudakidd  Offline
Better read this then (towards the bottom under "Special Instrutions).
http://www.mcleodind.com/faq.html#clutch_diagnostics
Re: Clutch clatter [Re: Kudakidd] #380676
07/21/09 03:09 PM
07/21/09 03:09 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I'm telling you guys, you can say that proper break-in is hog wash till your blue in the face, but when your clutch starts acting up or goes out prematurely, don't go boo-whooin
Heres another link, just scrole down.
http://www.centerforce.com/faqs.tpl?cart=1248208439729968
Re: Clutch clatter [Re: joedust451] #380677
07/21/09 03:19 PM
07/21/09 03:19 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
You know what they say about opinions.....
Every clutch ive had from day one got two easy launches and never looked back...never had one issue, never a blue spot on the Flywheel or PP let alone blue on the face.
I dont want to drag who told me this (well known in the trans world) , but I asked what I needed to do to break my clutch in before hitting the track...was told by time its moved around a few times and off the trailer to let it rip....hasnt slipped yet, and no chatter
So all these guys at the track with 4-5 speeds, go drive there rig for 50 miles to break one in....I dont think so.
Re: Clutch clatter [Re: quick77rt ] #380678
07/21/09 03:51 PM
07/21/09 03:51 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Those are DRAG cars, not street cars, if your lucky they see 20 miles a months, if you & others have deep pockets & don't mind throwing cash around, that cool, but i like my stuff to last, & if the manufacture tells me its BEST to do it this way, i'm not ashamed to do it, i'll swallow my pride & take there advice.
I'm not saying the clutch will shatter, blow up, or slip like mad if it isn't broken in right, it just never hurts to follow the manufactures recammendation for best results & performance from your new clutch.
Re: Clutch clatter [Re: joedust451] #380679
07/22/09 12:38 PM
07/22/09 12:38 PM
I pulled the adjustment rod out to add another nut, and it looks like it may have been installed wrong, causing it not to lock. The nut has a regular side and a flared side with slits and it was with the flared side towards the z bar. I'm assuming that it should probably be towards the metal washer causing it to be locked by the pressure from the washer? Also the adjustment rod has a flat side with hook piece off center. Does the flat side go on the side where it connects to the z bar or the opposite side where it connects?
Thanks,
Re: Clutch clatter [Re: Crizila] #380680
07/22/09 12:45 PM
07/22/09 12:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Well, after reading some posts, I could be wrong. - how rare is that!!
Fastest 300
