Re: 70 E body AC vacuum grommet Which Way? [Re: BartekP] #380255
11/22/09 10:21 PM
11/22/09 10:21 PM
cataclysm80 Offline OP
Where should I plug vacuum hose that goes through that grommet? Inside the car it goes to A/C box, but where is the vacuum supplied in the engine bay?
Good to see some action on this thread again!
There should be a vacuum port on your intake manifold. It is a threaded hole on the intake manifold and there are different plugs that screw into it depending on what options your car has.
There is a plug with no vacuum nipple for manual brake non AC cars.
There is a plug with a big vacuum nipple for power brake non AC cars.
There is a plug with a big & a small vacuum nipple for power brake with AC cars.
There is a plug with a big & 2 small vacuum nipples for power brake with AC & something else I'm not sure of. (the second small nipple isn't for cruise control, because that hooks to the brake booster check valve)
There may be other plugs also. There's probably one with only a small vacuum nipple for manual brake AC cars, etc.
distributor vacuum advance & PCV both go to the carb.
Anybody find out any more info about the different temperature cables?
Tav
Re: 70 E body AC vacuum grommet Which Way? [Re: cataclysm80] #380256
11/23/09 07:47 AM
11/23/09 07:47 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Tav
no,but what about this one. ive got the early? style of routing on my -70 cuda,where the temp-cable goes in to the coupe through the grommet with 2 holes,located under the blower motor.question= on my grommet with 2 holes,one of the holes has an outsticking(a couple og mm)piece molded in,its like a bit of a hose.so im wondering if that hole is for the temp-cable? or the vaccum hose?
Re: 70 E body AC vacuum grommet Which Way? [Re: cuda-sweden] #380257
11/24/09 12:30 AM
11/24/09 12:30 AM
I believe that hole is for the temp cable.
I'd also like to add that whether the temp cable came out under the blower motor or under the brake booster in 1970 doesn't seem to be build date related. It's not an early vs late thing. My car happens to be an early car (8-26-69), but the other cars I know of that exit under the blower motor are pretty much spread out through the year, with plenty of cars built between them that have the cable exiting under the brake booster.
I'm not sure why they exited the through the firewall in two different places in 1970. It doesn't seem to have anything to do with build date, cuda vs. challenger, or transmission. I don't think it has to do with engine selection. Someone had suggested that manual drum brake cars had the exit under the blower motor, but that's been proven wrong twice now.
Any ideas, or info is appreciated.
Tav
Re: 70 E body AC vacuum grommet Which Way? [Re: cataclysm80] #380258
11/24/09 03:07 AM
11/24/09 03:07 AM
Poland
BartekP Offline
BartekP  Offline
Poland
Grommet in my car (1970 318 A/C) was mounted from inside - looking on a dirt, there was no cable when I bought the car but that grommet doesn't look like cable went through it, second opening in rubber nipple is quite tight
'70 Challenger SE '77 Dodge M880/W200 '08 Magnum R/T
Re: 70 E body AC vacuum grommet Which Way? [Re: BartekP] #380259
11/27/09 01:30 PM
11/27/09 01:30 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
jorå,also my -70 cuda with under blower motor grommet,is a manual brake car.anyway its time to answer the question off stiffnes my original temp cable is with a stiff/solid inner wire,just like a lawn mower type of wire.and i think r.ehrenberg might have those on his e-båg web site.check it out he needs help with the alimony
Re: 70 E body AC vacuum grommet Which Way? [Re: cuda-sweden] #380260
11/28/09 06:33 PM
11/28/09 06:33 PM
Poland
BartekP Offline
BartekP  Offline
Poland
I mount the firewall insulation pads and I noticed that my temp cable is routed through wrong hole, on the picture no1 are insulation clip holes, where should go temp cable? and what are holes 2,3,4 for?
washer foot pump & hoses?
Re: 70 E body AC vacuum grommet Which Way? [Re: BartekP] #380261
11/28/09 08:23 PM
11/28/09 08:23 PM
Your temp cable is going through the correct hole. It replaces one of the insulation pins.
Hole 2 is used for the grommet that the manual windshield washer hoses pass through, or is plugged with a body plug if you have an electric windshield washer pump.
Hole 3 is for the clutch rod on a manual transmission, or is plugged with a body plug if you have an automatic transmission.
Holes 4 are for the manual windshield waher foot pump, and would be undrilled dimples if you had an electric windshield washer pump.
Tav
Re: 70 E body AC vacuum grommet Which Way? [Re: cataclysm80] #380262
11/28/09 09:09 PM
11/28/09 09:09 PM
Poland
BartekP Offline
BartekP  Offline
Poland
thanks
It had manual washer pump
Re: 70 E body AC vacuum grommet Which Way? [Re: cataclysm80] #380263
01/15/10 11:50 PM
01/15/10 11:50 PM
I heard about another car belonging to GKMOPAR that had the grommet for the cable that comes through under the blower motor.
It's a December 1969 car with manual drum brakes.
Tav
Re: 70 E body AC vacuum grommet Which Way? [Re: cataclysm80] #380264
01/16/10 02:59 PM
01/16/10 02:59 PM
Hilliard, Ohio
GKMOPAR Offline
GKMOPAR  Offline
Hilliard, Ohio
My 1970 Challenger Dec 1969 build date has the grommet mounted on the inside. Gerry
Re: 70 E body AC vacuum grommet Which Way? [Re: GKMOPAR] #380265
01/16/10 05:15 PM
01/16/10 05:15 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
70 barracuda SPD 9-11-69 with the grommet mounted on the inside...Power disc and cruize control...And I may have run my cable in the wrong routing...I've got it running out by the booster but the AC box has the clip that would have held the cable for the inside routing....In any event, It is the best routing now because of the header clearance...
