70 E body AC vacuum grommet Which Way?
#380235
07/19/09 04:53 PM
07/19/09 04:53 PM
Posts: 4,165 Florida
cataclysm80
Somehow I forgot to take a picture of this part before it came off the car. Is it supposed to mount on the engine compartment side of the firewall, or the passenger compartment side of the firewall? Also, which is the correct of 3 possible clock positions for this grommet?
While I'm at it, Where's the best place to get the temp control cable for the water valve? I'd like to have the one that goes through this grommet, but if I have to I could use the one that comes out by the brake booster.
The reproduction cables I've seen use a stiff wire, but I've never had the chance to check out an original cable off the car. (mine was missing) Do originals also use a stiff wire, or are they more flexible for easier routing? Do I need to look for NOS, used, or repro? If repro, who makes these cables?
Many thanks to any who help! This cable situation is one of those little things that's puzzled me since I got the car 11 years ago.
Tav
Re: 70 E body AC vacuum grommet Which Way?
[Re: Snoopy]
#380243
07/21/09 10:10 PM
07/21/09 10:10 PM
cataclysm80
From the looks of the one you posted, I would say that one was mounted from the engine side of the firewall.
Thanks Snoopy! I agree, it does look that way.
I've also just heard of two more cars owned by ebodyseast that both came with the grommet mounted from the engine side of the firewall.
That makes the score 3 engine side, 2 passenger side.
It seems odd that the factory would mount the grommet from either location.
Does anybody else have one?
Tav
[Re: FJ5_Fish]
#380245
07/21/09 11:52 PM
07/21/09 11:52 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Since it doesn't affect the function, it looks like the guy on the line was allowed to install from whatever side was most convenient at the time. I would vote for the engine bay side installation purely from a safety stand point as long as the pointy ends of the screw didn't pose a threat to the passenger. There is nothing like shoving your hand into dark tight place and pulling back a bloody hand.
[Re: cataclysm80]
#380248
07/27/09 11:57 PM
07/27/09 11:57 PM
Hey Tav, Your original part has all the clues you would ever need. If the grommet had been mounted from the inside of the car, it would not have been exposed to all the dirt and grime that is evident in your first picture. You can compare the difference by looking at the picture Snoopy posted. The part of the grommet that is shown in his photo is dirty from being exposed from the inside out. Your example shows an opposite dirt pattern because THAT area of the grommet was on the INSIDE during the life of the car. Notice the rubber area where the screws once held it in place. It is clean and black because the dirt from the engine compartment was not able to permeate behind them. Just think of how dirty the inside of the car would have to be if this pattern had resulted from being mounted INSIDE the car.
[Re: FJ5_Fish]
#380251
11/22/09 06:15 AM
11/22/09 06:15 AM
Posts: 36 Poland
BartekP
Poland
Where should I plug vacuum hose that goes through that grommet? Inside the car it goes to A/C box, but where is the vacuum supplied in the engine bay?
'70 Challenger SE
'77 Dodge M880/W200
'08 Magnum R/T
