Re: Carter AVS or Thermoquad
[Re: otrAlive]
#378650
07/18/09 08:15 AM
07/18/09 08:15 AM
RapidRobert
AVS-square bore iron intake. TQ-spreadbore iron intake
[Re: otrAlive]
#378652
07/18/09 08:39 AM
07/18/09 08:39 AM
RapidRobert
no apology needed & I knew(as I was typing) that I was missing something because if you have a demon right now you would know that it is a square bore. So the Q is does the TQ and or the AVS have the same fuel inlet location as your Demon carb. A suggestion, since you are not OE you could bend up a line much cheaper than purchasing a correct piece
[Re: otrAlive]
#378654
07/18/09 09:56 AM
07/18/09 09:56 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I currently have a fuel hose going from the fuel pump to carb and want to install a correct fuel line instead. I have a Demon 750 carb installed now. How can I determine if my 71 Duster 340 originally came with a Carter AVS or Thermoquad carburetor?
thanks, Floyd
If an original 340,it came with a Thermoquad.Also,the 71 T/Q is the only air metered T/Q.Not the best design,but work if tuned right.Also,very hard to find if you don't have one. All other T/Q's are solid fuel metered. fuel.
[Re: 62maxwgn]
#378655
07/18/09 11:26 AM
07/18/09 11:26 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
thanks, Floyd
I sold one at carlisle last week for $115 with an NOS rebuild kit everything worked , nothing frozen , I'm guessing I gave it away.
To the OP , does it MATTER what carb your car really HAD? The factory line is not going to fit on your current carb , you'll have to make one as mentioned.
