Will JB Weld live in this application? #377900
07/17/09 02:25 AM
07/17/09 02:25 AM
Today? Who Knows?
1_WILD_RT Offline OP
Management Trainee
Management Trainee
Today? Who Knows?
I'm gonna try it & I believe it will be fine, but a buddy of mine insists it's gonna fail.. What do you think...
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377901
07/17/09 02:26 AM
07/17/09 02:26 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
What I've done is epoxy these into my valve covers..
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377902
07/17/09 02:27 AM
07/17/09 02:27 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
So I can mount baffles...
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377903
07/17/09 02:30 AM
07/17/09 02:30 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
So the breather & PCV have proper baffles
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377904
07/17/09 02:31 AM
07/17/09 02:31 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
PCV
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377905
07/17/09 02:55 AM
07/17/09 02:55 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sure will make a neat noise if the JB weld does fail and that baffles falls onto the rocker arms
Don't you think tig welding some little 'pegs' onto the valve cover would have been a more permanent fix?
Re: Will JB Weld live in this application? [Re: OzHemi] #377906
07/17/09 03:02 AM
07/17/09 03:02 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
On the one side I agree & I considered it, but the material is cast & fairly thin.. I wouldn't try welding it myself but my buddy who is insisting it will fail is an absolute artist with the TIG.. But I've known of racers using JB Weld in much more stressed areas with no problem.. And I felt by usiing the "T"nuts I have plenty of surface area & I roughed up the back of the "T"nuts pretty good... The cast aluminum I left raw other then cleaning throughly...
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377907
07/17/09 04:09 AM
07/17/09 04:09 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I know it will work. I have some of those Cal Custom valve covers and they didn't come with baffles. I just have some chincy sheet metal screws that barely grab into very shallow casted holes held in by JB Weld.
Been that way since about 1994. With the stout suspension and cruising at 3800 RPM for 40 hours across country they have never vibrated loose.
Now about every other nut and bolt on the car has managed to loosen itself in the meantime. But those dumb baffles have stayed in place. My front spring eye nuts loosen all the way up about in a years time.
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377908
07/17/09 06:50 AM
07/17/09 06:50 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I would have tig welded in alumminum standoffs and used mounting bolts with saftey wire. Those little screws could do alot of damage if one comes loose. You could still safety wire and at least if something came loose it would all stay together.
Don't all the holes in the baffle kinda of defeat the purpose.
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377909
07/17/09 07:51 AM
07/17/09 07:51 AM
NJ
440challenger Offline
NJ
tack the baffle in all four corners and your done
Re: Will JB Weld live in this application? [Re: 440challenger] #377910
07/17/09 08:10 AM
07/17/09 08:10 AM
Cincinnati, Ohio
Cincinnati, Ohio
It'd be tough to clean the valve cover thoughly if you could not get the baffle out exspecially if there was some kind of failure.
FWIW I have drilled through the valve covers to mount baffles, doesn't look as nice but at a glace I could tell all my bolts were in place and it didn't leak.
Re: Will JB Weld live in this application? [Re: Challenger 1] #377911
07/17/09 08:24 AM
07/17/09 08:24 AM
New Hampshire
W
whitemtnelf Offline
whitemtnelf  Offline
W
New Hampshire
My father had a boat with an old 40hp Evinrude outboard. He stripped the threads on one of the cylinders and decided to give JB weld a try. I tried telling him to use a heli-coil instead but once the old man decided something that was it. I thought for sure that he'd have a 50mm round flying as soon as the motor started. But to my surprise it held for many hours of use. Moral of the story - I'd be real comfortable with your use.
Re: Will JB Weld live in this application? [Re: Challenger 1] #377912
07/17/09 11:30 AM
07/17/09 11:30 AM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
The screw I'm actually gonna use are stainless steel allens with a nylon insert so they don't loosen unless you want them to...
I actually feel all the little holes are gonna help improve drainage.. They started live as nailer plates for reinforcing wood construction, I've had them laying around for a few years & they were close to the right size..
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377913
07/17/09 01:44 PM
07/17/09 01:44 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Looks good to me...
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377914
07/17/09 02:05 PM
07/17/09 02:05 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Another vote for JB Weld working just fine.
Planning to do some framing under there someday?
To answer your next question, I think PT would work better in that environment than plain Doug Fir...
Down to just a blue car now.
Re: Will JB Weld live in this application? [Re: 68HemiB] #377915
07/17/09 02:17 PM
07/17/09 02:17 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Doug Fir would be better to support the rocker shaft though...
I wonder if Simpson Strong-Tie would have motorsport support for you?
Re: Will JB Weld live in this application? [Re: OzHemi] #377916
07/17/09 02:33 PM
07/17/09 02:33 PM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
So I should probably just scrap the one I carved out of Oak...E...
As far as Support goes, I'm more likely to get support from Homer Simpson...
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377917
07/17/09 02:50 PM
07/17/09 02:50 PM
Cincinnati, Ohio
Cincinnati, Ohio
I hear you, I love to use what I got laying around too.
Re: Will JB Weld live in this application? [Re: 1_WILD_RT] #377918
07/17/09 03:07 PM
07/17/09 03:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I don't have holes in mine. Filing it with oil is a pain.
Re: Will JB Weld live in this application? [Re: autoxcuda] #377919
07/17/09 03:11 PM
07/17/09 03:11 PM
Today? Who Knows?
Management Trainee
Management Trainee
Today? Who Knows?
That is exactly what I remember about trying to fill with the early stock covers & why I thought the little holes would help... The good news is we all understand the need for baffles, something the companies making most aftermarket covers seemed to forget about...
