Scamp is almost done.. again
#377860
07/17/09 01:02 AM
07/17/09 01:02 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
I almost have my 71 scamp done for the 3rd time. for those who arn't familiar with the car, I had restored it first about 4 years ago, then went through an accident involving a roll over 3 years ago, then I restored it yet again and finished it last fall, but I just wasn't happy with it, so out came the motor yet again for a go-over this last winter. also involved was some suspension mods- tubular upper A arms, big sway bars, disc brakes and I have cal-trac bars, but they need installing. the motor use to be stock with only a 4 bbl and duel exhaust, but now sports performer intake, holley 600, hotter cam(can't quite remember the specs) ported 302 heads with heavy duty mp springs, windage tray, headers, electronic ignition, and my tranny made up of a shift kit, 3000 tc and even a line lock. Im still running the stock rear for now (7.25 with 2.76) but I'm in the process of cutting down an 8.75 and I have a 3.91 sure grip to go in! Im also going with a different rim- probably weld pro-stars, but for now I have blacked out ralleys with late model centers. also in the plans is a custom dash cluster and move all of the aftermarkey gauges where I can see them better. I just took these pictures this afternoon when the car finally rolled out of the shop under its own power for the first time with the new set up.
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
Re: Scamp is almost done.. again
[Re: tippytoe]
#377865
07/17/09 10:26 AM
07/17/09 10:26 AM
mopars_1
Ridgeland Wi
lol ya, it got pretty beat up. Ill see if I can get a few pics on here.
[Re: furious]
#377869
07/17/09 01:45 PM
07/17/09 01:45 PM
mopars_1
Ridgeland Wi
I repaired it. new 1/4, new roof skin, new roof bracing, and A LOT of straitening of the frame rails and other panels. took a lot of work, thats for sure!
[Re: mopars_1]
#377873
07/20/09 09:38 AM
07/20/09 09:38 AM
Posts: 1,615 Table Rock Lake Missouri
furious
Amazing job, you are to be commended!
