BB cast crank flywheel balancing question #376984
07/16/09 07:21 AM
07/16/09 07:21 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Hello. I am going to drop my flywheel off to the machine shop this afternoon and I just want to verify a couple of things before I do.
A. This is the correct drawing for balancing a regular flywheel for use with a cast crank engine?
B. This drawing will work for either 10.5 or 11 flywheels? (I have an 11 inch)
Thanks!
Stan
Re: BB cast crank flywheel balancing question [Re: HemiStan] #376985
07/16/09 08:20 AM
07/16/09 08:20 AM
JOPLIN MO 64804
RBDART1 Offline
RBDART1  Offline
JOPLIN MO 64804
As long as the balance[weights] matches whatever engine you are using
Re: BB cast crank flywheel balancing question [Re: HemiStan] #376986
07/16/09 10:30 PM
07/16/09 10:30 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Since the weight removed by drilling is a specific distance from the center of the wheel, it doesn't matter what the outer diameter is.
Re: BB cast crank flywheel balancing question [Re: John_Kunkel] #376987
07/16/09 10:37 PM
07/16/09 10:37 PM
If you are a math whiz (this deal takes trig ) and with a drill press and that large bit and a depth mike w a point you would be able to pinpoint the locations & do it your self if you were so inclined.
Re: BB cast crank flywheel balancing question [Re: RapidRobert] #376988
07/17/09 05:42 AM
07/17/09 05:42 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
Thanks for the replies.
I have actually thought about doing it myself but there is a machine shop in town that just came under new management. I have been looking for a "good" machine shop because I seem to have a pile of different parts that I need some work done to. This flywheel is going to be a "test". Depending on how they do with it will determine if they get any more of my stuff.
Stan
Re: BB cast crank flywheel balancing question [Re: HemiStan] #376989
07/17/09 08:15 AM
07/17/09 08:15 AM
Stan
Have them save their trig figures & give them to you that way if you do one of these 'wheels again you will have that info at your disposal
Re: BB cast crank flywheel balancing question [Re: RapidRobert] #376990
07/17/09 10:28 AM
07/17/09 10:28 AM
IMGTX Offline
IMGTX  Offline
Who needs trig.
Draw it up in CAD and print a full size paper template. glue it to the surface and use it to mark and drill the flywheel. That drawing would take less than 10 minutes with the rest of the dims.
I do stuff like that all the time.
If the flywheel surface is too irregular to glue to (it probably is) print it on posterboard or glue it to a piece of thin steel and drill through the steel into the flywheel.
If I had some better dims of the holes I could drop a cad file on you. You should be able to get them printed pretty cheap.
It can be done without the center holes but I like as much detail as possible to prevent mistakes. If anyone has those dims send them too me. I will in return give everyone a CAD file of the drawing.
I will try to I will see if I can find them in my old books.
Here is a pic of a mockup posterboard mount I made. Plotters will easily print on poster board and just cut it out.
Here is a picture of the same mount glued to a cheap piece of metal to form a temp mount just for fun. I just cut and drilled along the dotted line. The final one will be made from 1/8" steel not a cheapo computer case.
Re: BB cast crank flywheel balancing question [Re: IMGTX] #376991
07/17/09 03:15 PM
07/17/09 03:15 PM
Rio Linda, CA
Rio Linda, CA
I see no need for either trig or CAD for the layout, a 6" scale and a protractor are all that's needed.
Re: BB cast crank flywheel balancing question [Re: John_Kunkel] #376992
07/17/09 08:52 PM
07/17/09 08:52 PM
IMGTX Offline
IMGTX  Offline
That's too easy...
Where is the fun in that.
