What 500ci combos and 1/4 mile times to expect? #376730
07/15/09 10:26 PM
07/15/09 10:26 PM
Rhode Island
GoodfellaHenry70 Offline OP
Rhode Island
Hi guys,
I have a 69 road runner with a new 496 stroker setup, auto, 2800 stall converter, running 275/60/15 Drag Radials and thinking about what kinda times I can run at the track.
Not sure what gears to toss in, 3:55, 3:91, 4:10?
I'm running a cam with about 550" lift and 285 duration, eddy aluminum heads, 1 7/8" headers and an eddy 800cfm for now.
Looking to hear your similar based combos, with or without NOS, gears, specificly about and 1/4 times and mph.
Thanks for your input
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage." Just call me Hank.
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376731
07/15/09 10:37 PM
07/15/09 10:37 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
At .050 duration and LSA?? advertised tells vertualy nothing!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376732
07/15/09 10:39 PM
07/15/09 10:39 PM
northeast texas
strokin73cuda Offline
northeast texas
So far my combo is very similar to yours but with a six pack and 3.55s I'm curious to see too.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: What 500ci combos and 1/4 mile times to expect? [Re: strokin73cuda] #376733
07/15/09 10:57 PM
07/15/09 10:57 PM
hartsburg mo
biggerredz71 Offline
hartsburg mo
505,70RR,4200 stall,hughes cam 250-255 dur 576in 593 ex,source headed,victor intake,850dp,355 gears,stil wating to go to track as well.295-50-15 tires
Re: What 500ci combos and 1/4 mile times to expect? [Re: biggerredz71] #376734
07/16/09 12:26 AM
07/16/09 12:26 AM
northeast texas
northeast texas
Hyd roller @.50 mine is 246 in. 252 ex. 0n 112 lobe seperation .555 lift in. .548 lift ex. at cam 1.5 rockers my heads are eddy rpms otb intake ports the exhaut have been ported slightly, 1 7/8 hooker comp. 3"exhaust w muffs ross custom flattops 10.5 to 1 c.r. with 84 cc head 496 stroker stock converter 3.55s 315/50/15 M.T. drag radials my best so far 1/8 mile local track in the heat 1.73 60' 4.936 330' 7.588 660' @ 94 mph wallace caculaters translate that to 11.89 @ 116.56 and that will probably be pretty close I think the car does have a little more as I'm still working out a few small bugs with a little help from this site.
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376735
07/16/09 01:11 AM
07/16/09 01:11 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
My combo is a 383/496, 12.20:1, Hughes cam/valvetrain, Cam is 272@.050/.619 with 1.5 Hughes roller rockers with their hold down kit, Hughes stud girdle,Stage VI ported heads, ported Victor intake, Pro-Systems 4150 1000cfm carb and Nitrous Works plate system. Car weighes 3400 with me in it, runs 6.87@102.49 1/8th, 1.52 60 ft, 10.59@123 1/4 on motor, on NOS with bad tune-up (very rich as per Monte) 6.47@107.47, 1.41 60ft, 10.22@128 1/4. Looking for high 9'S with good tune-up on NOS as per Monte.....Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376736
07/16/09 01:29 AM
07/16/09 01:29 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
im just about to fire mine up its got the eddy wdge heads 528 lift cam 11-1 comp max wedge intake with 2 600 holleys and a 2800 stall conv and 4-30s in a 62 dodge dart, ill stay in touch to let you know
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376737
07/16/09 07:09 AM
07/16/09 07:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Hi guys,
Get a holley 850DP that eddy 800 won't be enough and you'll fade at 3/4 track, and 3.91 at least. What drag radials? if you tune is on and you run 3.91's you'll blow BFG's apart...Hoosier or ET street radials and you'll be ok.
When you get it all sorted out it should run 11.80's or so maybe better.
Coming soon!!!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: Mr.Yuck] #376738
07/16/09 07:53 AM
07/16/09 07:53 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I just took my Coronet to the track last week with a 500 inch with Eddy heads. Using a cam with 247/255 and 549/572 lift, 1 3/4 headers, 3000 stall, and 3:55's I went [Email]12.00@113[/Email] with regular 275/60 BFG street tires. Mind you this was the first time me or the car have ever been down the 1/4 mile. My car weighs 3975lbs. I'm sure if you use 3:55's with some drag radials you can drive easily to the track and run 11.80's at least.
Re: What 500ci combos and 1/4 mile times to expect? [Re: Jeff_383] #376739
07/16/09 09:03 AM
07/16/09 09:03 AM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
275/60/15 BFG will not get it done on 69 runner with stock style suspension. if you can get 60' in the 1.70s look for 11.7-11.8 in 1/4. If you can squeeze 325/50s in, you might have a chance.
Re: What 500ci combos and 1/4 mile times to expect? [Re: GoodfellaHenry70] #376740
07/16/09 09:32 AM
07/16/09 09:32 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Had a 68 all steel coronet 499" w/525 comp hyd cam, stock eddy heads, 800 edelbrock, full tti system, 3.54 rear, 26" e/t streets, that would 60' 1.72, ran 12.20 @ 111, but was running out of fuel a wee bit down track. Weight approx 3900 w/driver.
Re: What 500ci combos and 1/4 mile times to expect? [Re: buildanother] #376741
07/16/09 09:53 AM
07/16/09 09:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can thank that weak carb for that. Put a DP on it and you'll be into the 11's easy.
Coming soon!!!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: Mr.Yuck] #376742
07/16/09 10:40 AM
07/16/09 10:40 AM
chicagoland,usa
chicagoland,usa
Yeah, I was also using an elec pump, pulling fuel through the 5/16 fuel line through the stock pickup screen that was most likely never seen after car was built in 68. That car's(should of kept it) gone now anyways.
Re: What 500ci combos and 1/4 mile times to expect? [Re: buildanother] #376743
07/16/09 10:47 AM
07/16/09 10:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
5/16 line is ok. Seen cars run low 11's w/ it, now a dirty sock 'aint gonna help.
Coming soon!!!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: Mr.Yuck] #376744
07/16/09 11:13 AM
07/16/09 11:13 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I pulled a 1.80 60ft. with those street 275/60 BFG's and only SS springs.
Re: What 500ci combos and 1/4 mile times to expect? [Re: Jeff_383] #376745
07/16/09 11:53 AM
07/16/09 11:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
with your set-up a good pair of DOT's would get you way into the 11's. I pulled 1.68 w/ ET streets on a 12.90 car. 1.80 is good for a mid 13 second car
Coming soon!!!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: Mr.Yuck] #376746
07/16/09 12:35 PM
07/16/09 12:35 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
It's hard to judge what is a good or bad 60ft. for an E.T. I've seen shitty 60ft.'s end with fantastic E.T.'s I've also seen great 60ft.'s turn into turds at the other end. Some cars consistantly run bad 60ft's and run better than cars with good 60ft.'s. My real point is you don't always need to shove a monster tire in back to run good, even with basic combinations.
Re: What 500ci combos and 1/4 mile times to expect? [Re: Jeff_383] #376747
07/16/09 12:54 PM
07/16/09 12:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ture and since you have a 4 speed I'm not sure what you were dropping the hammer at.
Coming soon!!!!
Re: What 500ci combos and 1/4 mile times to expect? [Re: Mr.Yuck] #376748
07/16/09 02:40 PM
07/16/09 02:40 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
No, I have an auto and idled out of the whole until about 30ft then gradualey floored it.
Re: What 500ci combos and 1/4 mile times to expect? [Re: Jeff_383] #376749
07/16/09 09:39 PM
07/16/09 09:39 PM
Central NC
gch Online content
gch  Online Content
Central NC
For a primarily street driven car I would run the 3.55's.Any more than that will not give you much if any E.T. gain on drag radials but your driveability will suffer unless you like spinning 3000-3500 rpm at 60-70mph on the freeway.
The stroker makes so much torque you don't need to rpm it to death.Let the torque move you.
