What 500ci combos and 1/4 mile times to expect?
#376730
07/15/09 10:26 PM
07/15/09 10:26 PM
Posts: 85 Rhode Island
GoodfellaHenry70
Rhode Island
Hi guys, I have a 69 road runner with a new 496 stroker setup, auto, 2800 stall converter, running 275/60/15 Drag Radials and thinking about what kinda times I can run at the track. Not sure what gears to toss in, 3:55, 3:91, 4:10? I'm running a cam with about 550" lift and 285 duration, eddy aluminum heads, 1 7/8" headers and an eddy 800cfm for now. Looking to hear your similar based combos, with or without NOS, gears, specificly about and 1/4 times and mph. Thanks for your input
"No big deal...It's called Advanced Dilusionary schizophrenia with involuntary narcissistic rage."
Just call me Hank.
Re: What 500ci combos and 1/4 mile times to expect?
[Re: GoodfellaHenry70]
#376735
07/16/09 01:11 AM
07/16/09 01:11 AM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
My combo is a 383/496, 12.20:1, Hughes cam/valvetrain, Cam is 272@.050/.619 with 1.5 Hughes roller rockers with their hold down kit, Hughes stud girdle,Stage VI ported heads, ported Victor intake, Pro-Systems 4150 1000cfm carb and Nitrous Works plate system. Car weighes 3400 with me in it, runs 6.87@102.49 1/8th, 1.52 60 ft, 10.59@123 1/4 on motor, on NOS with bad tune-up (very rich as per Monte) 6.47@107.47, 1.41 60ft, 10.22@128 1/4. Looking for high 9'S with good tune-up on NOS as per Monte.....Matt
#376737
07/16/09 07:09 AM
07/16/09 07:09 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Hi guys,
Get a holley 850DP that eddy 800 won't be enough and you'll fade at 3/4 track, and 3.91 at least. What drag radials? if you tune is on and you run 3.91's you'll blow BFG's apart...Hoosier or ET street radials and you'll be ok. When you get it all sorted out it should run 11.80's or so maybe better.
#376740
07/16/09 09:32 AM
07/16/09 09:32 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
Had a 68 all steel coronet 499" w/525 comp hyd cam, stock eddy heads, 800 edelbrock, full tti system, 3.54 rear, 26" e/t streets, that would 60' 1.72, ran 12.20 @ 111, but was running out of fuel a wee bit down track. Weight approx 3900 w/driver.
[Re: buildanother]
#376741
07/16/09 09:53 AM
07/16/09 09:53 AM
Mr.Yuck
Brookeville, Md
you can thank that weak carb for that. Put a DP on it and you'll be into the 11's easy.
[Re: buildanother]
#376743
07/16/09 10:47 AM
07/16/09 10:47 AM
Mr.Yuck
Brookeville, Md
Yeah, I was also using an elec pump, pulling fuel through the 5/16 fuel line through the stock pickup screen that was most likely never seen after car was built in 68. That car's(should of kept it) gone now anyways.
5/16 line is ok. Seen cars run low 11's w/ it, now a dirty sock 'aint gonna help.
[Re: Jeff_383]
#376745
07/16/09 11:53 AM
07/16/09 11:53 AM
Mr.Yuck
Brookeville, Md
I pulled a 1.80 60ft. with those street 275/60 BFG's and only SS springs.
with your set-up a good pair of DOT's would get you way into the 11's. I pulled 1.68 w/ ET streets on a 12.90 car. 1.80 is good for a mid 13 second car
[Re: Jeff_383]
#376747
07/16/09 12:54 PM
07/16/09 12:54 PM
Mr.Yuck
Brookeville, Md
It's hard to judge what is a good or bad 60ft. for an E.T. I've seen shitty 60ft.'s end with fantastic E.T.'s I've also seen great 60ft.'s turn into turds at the other end. Some cars consistantly run bad 60ft's and run better than cars with good 60ft.'s. My real point is you don't always need to shove a monster tire in back to run good, even with basic combinations.
ture and since you have a 4 speed I'm not sure what you were dropping the hammer at.
