Intake Question #376724
07/15/09 10:23 PM
07/15/09 10:23 PM
South of Seattle
MBigDaddyM Offline OP
South of Seattle
I have a 413 intake from a truck/industrial block, I had a guy email me asking if it would fit his 383. The 413 being an industrial motor had the huge heads with extra cooling passages and the intake has extra cooling passages. So will it fit the 383 and will the extra passages be an issue? BD
Will the last one leaving the US please turn out the lights.
Re: Intake Question [Re: MBigDaddyM] #376725
07/15/09 10:25 PM
07/15/09 10:25 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Aside from the issue of having cooling passages in the intake which normal manifolds don't use, a 413 is an RB and a 383 is a B engine, so different width intakes.
Re: Intake Question [Re: OzHemi] #376726
07/15/09 10:42 PM
07/15/09 10:42 PM
South of Seattle
South of Seattle
It has been my understanding that 383's had 906 heads from 68-70, the same heads used on the 440 so if B & RB engines use the same heads, shouldn't they be able to interchange intakes? -BD
Re: Intake Question [Re: MBigDaddyM] #376727
07/15/09 10:44 PM
07/15/09 10:44 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
NO.Heads are the same but blocks are different.The RB is wider.Thats why its called RB not B.Rocky
Chrysler Firepower
Re: Intake Question [Re: MBigDaddyM] #376728
07/15/09 10:46 PM
07/15/09 10:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Heads will interchange between B & RB engines yes - but intakes won't do to deck height making RB intakes much wider.
Re: Intake Question [Re: MoparforLife] #376729
07/15/09 11:58 PM
07/15/09 11:58 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Only time a RB intake will fit a B engine is when you run Stage 6 MP heads.
I want my fair share
