Re: Cuda electrical ?
[Re: Challenger 1]
#376437
07/15/09 06:12 PM
07/15/09 06:12 PM
With all that added stuff you probably want a "continuous duty solenoid" Any good parts store/ marine/ motorhome joint will have them.
[Re: danbs23]
#376439
07/15/09 06:31 PM
07/15/09 06:31 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If you want to trace out a wire go here. http://www.mymopar.com/index.php?pid=27
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: danbs23]
#376441
07/16/09 12:45 AM
07/16/09 12:45 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
Before you start hooking those kinds of loads up to your factory wiring, you may want to read the articles found here. http://www.madelectrical.com/electrical-tech.shtmlThere's a wealth of sound information on this site, and it will help you design and build a safe reliable and well thought out upgrade/addition to your factory harness.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#376443
07/17/09 11:11 AM
07/17/09 11:11 AM
Posts: 1,527 minnesota
Kirby
minnesota
If you call him- he is EXTREMELY helpful- but takes a while.
