Educate me on 1970 B body brake boosters #376424
07/15/09 05:24 PM
07/15/09 05:24 PM
Rancho Cordova, California (Sa...
hemi71x Offline OP
hemi71x  Offline OP
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Educate me on 1970 B body brake boosters [Re: hemi71x] #376425
07/15/09 05:34 PM
07/15/09 05:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's a side shot showing a Hemi(top) vs "B body booster,....the Hemi rear rod length set up is approx 3 1/2 + inches,(measureing from the rear of the booster body).......the B body will be around 5" +/- 1/2 ", all de[pends how it was assembled, the intermediate linkage takes up the decreptional difference
Re: Educate me on 1970 B body brake boosters [Re: DAYCLONA] #376426
07/15/09 05:40 PM
07/15/09 05:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here's the "correct" check valve for your V code application Paul
Re: Educate me on 1970 B body brake boosters [Re: DAYCLONA] #376427
07/15/09 05:42 PM
07/15/09 05:42 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
A V code B body 99% of the time with PDB would use this style master, with the lines inboard of the motor
Re: Educate me on 1970 B body brake boosters [Re: DAYCLONA] #376428
07/15/09 05:43 PM
07/15/09 05:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
top veiw of cap
Paul, if/when you assemble your Benbix set up, EVERYTHING gets painted semi gloss/30% reduction BLACK, assemble the master to the booster(after you've adjusted the depth/length of the plunger rod, for the master your using)....everything, gaskets, nuts, master cylinder, master cover and bailing wire get painted black as an assembled unit, as it was delivered to the assy line,...I've seen a few with painted grommets and check valves, and some with "clean" grommets and Check valves,...your call on that preference
Re: Educate me on 1970 B body brake boosters [Re: hemi71x] #376429
07/15/09 06:11 PM
07/15/09 06:11 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
http://cgi.ebay.com/ebaymotors/ws/eBayIS...em=260446812324
I have this one, if you might be interested.
Jim V.
Jim, that is definately a C body booster, the rear rod should be approx 7" +/- 1/2"......in your ad you state they are used in Hemi conversions, you're correct, when 100 point/gold OEM isn't important, and having the correct relocation is, the rear rod needs to be shortened, and the "Hemi" offset brackets must be for the alternate rear bolt pattern and not the Hemi spread
Re: Educate me on 1970 B body brake boosters [Re: DAYCLONA] #376430
07/15/09 09:39 PM
07/15/09 09:39 PM
Grand Rapids MI
N
N9671X2 Offline
N9671X2  Offline
N
Grand Rapids MI
I noticed somehow this post is showing up in 2 forums? Again, appreciate all the information!
https://board.moparts.org/ubbthreads/show...e=0#Post5354019
Re: Educate me on 1970 B body brake boosters [Re: N9671X2] #376431
07/15/09 10:00 PM
07/15/09 10:00 PM
hemi71x Offline OP
hemi71x  Offline OP
I don't know how this came about.
Myself, and dayclona had a couple of our postings deleted from that original posting.
One of our moderators has moved things around.
Re: Educate me on 1970 B body brake boosters [Re: hemi71x] #376432
07/15/09 11:55 PM
07/15/09 11:55 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Just the "Matrix" acting up again .......after the "machines" fix it, we'll remember none of this
