REMOVING TIRES FROM WHEELS #375660
07/14/09 10:36 PM
07/14/09 10:36 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Got a set of GT wheels, but want to keep them and sell the GT radials, I want to remove them, but I doubt they've been off the wheels since '78.
What would be a good way to prep them for break down and removal w/o hurting the tire or it's looks?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: REMOVING TIRES FROM WHEELS [Re: Magnumguy] #375661
07/14/09 10:43 PM
07/14/09 10:43 PM
scratchnfotraction Offline
have a tire shop do them
are they dry rotted/cracked?
you got a tire machine?
by hand with a tire iron and bumper jack using the front of a car to break the bead down with the foot of the jack
make sure you mark the direction of the tire and what corner they came of,for the new owner of old tires
Re: REMOVING TIRES FROM WHEELS [Re: scratchnfotraction] #375662
07/14/09 10:49 PM
07/14/09 10:49 PM
S.E.Ohio
S.E.Ohio
Not rotted at all. I was wondering if there was some way to "prep" them for removal.
Re: REMOVING TIRES FROM WHEELS [Re: Magnumguy] #375663
07/14/09 10:53 PM
07/14/09 10:53 PM
maybe wash them with simple green a couple good times,that gives the a good dry rubber look and brightens up the white letters
dont know what else can be done other than do it gently on the tire machine,use a vertical arm machine on them if possibale
Re: REMOVING TIRES FROM WHEELS [Re: scratchnfotraction] #375664
07/16/09 11:48 AM
07/16/09 11:48 AM
S.E.Ohio
S.E.Ohio
Anyone else?
Re: REMOVING TIRES FROM WHEELS [Re: Magnumguy] #375665
07/16/09 11:51 AM
07/16/09 11:51 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
the tires are junk. Who's going to buy tires that old??? UNSAFE
Coming soon!!!!
Re: REMOVING TIRES FROM WHEELS [Re: Mr.Yuck] #375666
07/16/09 02:06 PM
07/16/09 02:06 PM
S.E.Ohio
S.E.Ohio
I don't know, but it seems like someone folk do. Trailer queens I guess prefer originals, as they never see much, if any, driving
Re: REMOVING TIRES FROM WHEELS [Re: Magnumguy] #375667
07/16/09 02:11 PM
07/16/09 02:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Soak em with tire lube on both sides. That way there lubed for when they break the beads and less likely to damage those old tires.
I agree though, I would never run em on my car being that old. 31 years old?
And I'd be afraid to sell em, because if they failed the buyer is not gonna be happy with you.
Re: REMOVING TIRES FROM WHEELS [Re: Mr.Yuck] #375668
07/16/09 02:45 PM
07/16/09 02:45 PM
Az
Crizila Offline
Crizila  Offline
Az
For sure unsafe!!! You need to take them to a tire shop - after you take a big knife and slice open the side walls.
Fastest 300
