Re: 318 stroker
[Re: dodgefarmer]
#374704
07/14/09 10:21 AM
07/14/09 10:21 AM
quick77rt
Parts Problem
Parts Problem
Ive been looking at alot of different combos for a new x block build, im trying to stroke it yet keep the org bore size as small as possible. This really isnt what id do but the link shows a pretty well done stroked 318 http://74.125.155.132/search?q=cache:utA...=clnk&gl=us
Re: 318 stroker
[Re: snowmobiler7c]
#374705
07/14/09 11:54 AM
07/14/09 11:54 AM
Posts: 270 Washington, IL
Hughes
Washington, IL
As long as you get the right pistons you can make what you are doing work. However, I think you are going to be dissapointed in the performance using that combination of parts you listed. It is more money, but, another option is our 390 stroker kit for the 318.( http://www.hughesengines.com/Index/produ...mp;partid=25284 ) When you compare buying all of the parts individually, paying to recondition the rods and then pay someone to balance it, the $1600 for a complete balanced kit should start to look pretty good. Plus, the torque from these 390's is amazing. Give us a call if you get time and we can work with you on a complete, matched combination of parts to help you get the reults you want.
