anybody recognize this switch? #374634
07/13/09 11:27 PM
07/13/09 11:27 PM
Davis, California, USA
MrBelvedere2 Offline OP
Hey just wondering if anyone knows what this switch might go to..it has 3 connectors on the back, labeled "L" "B" and "H" and has 58024 stamped into the plastic, and also 323 3500 on the metal side, does it look familiar or does anyone know what it is? thank you.
1965 Plymouth Belvedere II hardtop
Re: anybody recognize this switch? [Re: MrBelvedere2] #374635
07/13/09 11:33 PM
07/13/09 11:33 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Looks like a fan blower motor switch, late '70s or ealy '80 judging by the knob style. Could be an F-body rear window defogger switch.
Re: anybody recognize this switch? [Re: MrBelvedere2] #374636
07/14/09 05:20 PM
07/14/09 05:20 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
See if there is some sliding to it between the first click and the second click. It may be a delay wiper switch, Should hav a 3rd click.
Looks like it would fit a late 70's to mid 80's van.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: anybody recognize this switch? [Re: Rug_Trucker] #374637
07/14/09 07:32 PM
07/14/09 07:32 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
It looks a lot like the '79 F-body rear window defroster switch (date code 0999) I have. Is the stem spring loaded?
With only three terminals, it can't be a wiper switch.
Re: anybody recognize this switch? [Re: MrBelvedere2] #374638
07/14/09 07:39 PM
07/14/09 07:39 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
The '79 F-body rear window defroster switch I have in front of me is very similar, with the same three termianls. It has a date code of 0999 and is part number 3747324.
Is the stem on your switch spring loaded and does it return to the center position after pushing it either up or down?
Re: anybody recognize this switch? [Re: In_The_Pink] #374639
07/15/09 10:43 AM
07/15/09 10:43 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
IT IS DEFINITELLY A BLOWER SWITCH...
B is Batt
L is Low
H is High
what else could it be if not SPEEDS for a blower
Re: anybody recognize this switch? [Re: MrBelvedere2] #374640
07/15/09 11:01 AM
07/15/09 11:01 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Wiper switch, mid-eighties fullsize truck-ramcharger? They had a funky switch similar to that.
Re: anybody recognize this switch? [Re: buildanother] #374641
07/16/09 12:56 AM
07/16/09 12:56 AM
thank you for the responses, no it is not spring loaded and doesn't return to the middle it will stay where you put it.now the other question, anyone need it????
