anybody recognize this switch?
#374634
07/13/09 11:27 PM
07/13/09 11:27 PM
Posts: 649 Davis, California, USA
MrBelvedere2
Hey just wondering if anyone knows what this switch might go to..it has 3 connectors on the back, labeled "L" "B" and "H" and has 58024 stamped into the plastic, and also 323 3500 on the metal side, does it look familiar or does anyone know what it is? thank you.
1965 Plymouth Belvedere II hardtop
Re: anybody recognize this switch?
[Re: MrBelvedere2]
#374636
07/14/09 05:20 PM
07/14/09 05:20 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
See if there is some sliding to it between the first click and the second click. It may be a delay wiper switch, Should hav a 3rd click.
Looks like it would fit a late 70's to mid 80's van.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: MrBelvedere2]
#374638
07/14/09 07:39 PM
07/14/09 07:39 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
The '79 F-body rear window defroster switch I have in front of me is very similar, with the same three termianls. It has a date code of 0999 and is part number 3747324.
Is the stem on your switch spring loaded and does it return to the center position after pushing it either up or down?
[Re: In_The_Pink]
#374639
07/15/09 10:43 AM
07/15/09 10:43 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
IT IS DEFINITELLY A BLOWER SWITCH...
B is Batt L is Low H is High
what else could it be if not SPEEDS for a blower
[Re: buildanother]
#374641
07/16/09 12:56 AM
07/16/09 12:56 AM
MrBelvedere2
thank you for the responses, no it is not spring loaded and doesn't return to the middle it will stay where you put it.now the other question, anyone need it????
