Re: Trans lube leaking out of my speedo cable?
[Re: John_Kunkel]
#374629
07/14/09 03:49 PM
07/14/09 03:49 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
Excellent pic John! I can see what looks like a C-clip and the black seal that it backs up to. How does that adapter come out of the trans?
[Re: Blakcharger440]
#374630
07/14/09 03:54 PM
07/14/09 03:54 PM
Posts: 15,487 Florida
scratchnfotraction
take the hold down clamp off note the dot and the #s that referance the # of teeth on the plastic gear so it goes back in correct the dot and the mark go together like in the pic and there is an o-ring on the plug that goes in the tranz
[Re: 1_WILD_RT]
#374632
07/14/09 04:52 PM
07/14/09 04:52 PM
Blakcharger440
Wichita,KS
Hey I have removed the speedo adapter and pulled the speedo gear out of it....how do I remove the spring and black seal inside of the adapter so that it wont leak when I put it back together ? I am trying this on a spare trans that I have in my garage first but when I remove the adapter on the one in my car should I go ahead and drain the trans fluid out first because it will come gushing out when I take the speedo adapter out? Keep the info coming guys you are great! I am learning new stuff every day with this car!
