Piston rings - which is which? #374025
07/13/09 03:11 PM
07/13/09 03:11 PM
London, UK.
P
prothed Offline OP
prothed  Offline OP
P
London, UK.
Just fitting some rings (Sealed Power E-424K) and the instruction sheet doesn't match what's in the box...
The label on the box says the rectangular section ring is the top ring, and the ring with a bevel on the top inside edge is the second ring.
No problem - but the instruction leaflet shows both of these as top rings, with the second ring having a bevel on the bottom side
Don't want to screw this up - which is which?
Thanks.
Re: Piston rings - which is which? [Re: prothed] #374026
07/13/09 03:58 PM
07/13/09 03:58 PM
All I can contribute is my C&A rings have the top(moly) ring w the bevel on the top inside and the cast 2nd ring has the bevel on the bottom inside(both w the dots on top. My sealed power set(cast,cast) has the same orientation. EDIT Even though my instructions show a ring w NO bevel for illustration purposes I have yet to open a pkg that had them(no bevel) in it so if someone does not have the answer, a call to them(oops forgot your location , better do an email) might be in order. The non bevel may be correct for your app or someone on the assy line might have grabbed the wrong ones
Re: Piston rings - which is which? [Re: RapidRobert] #374027
07/13/09 04:17 PM
07/13/09 04:17 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Re: Piston rings - which is which? [Re: prothed] #374028
07/13/09 04:23 PM
07/13/09 04:23 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The cast sealed power rings I bought came with the same rings for the top and middle. I did not get any square rings, all were beveled and appeared to be top rings. Only ring that were different were the oil rings...?
Re: Piston rings - which is which? [Re: DaytonaTurbo] #374029
07/13/09 04:27 PM
07/13/09 04:27 PM
Were the bevels on the top inside(top ring)and the bottom inside(2nd ring)? cast/cast w no shiny moly face on the top ring(s)
Re: Piston rings - which is which? [Re: RapidRobert] #374030
07/13/09 11:57 PM
07/13/09 11:57 PM
Manitoba, Canada
Manitoba, Canada
Base model sealed power cast rings for 440 standard bore size. All rings(except oil obviously) have the bevel on the same side as the dot. In fact all 16 rings are identical and all look like top rings. Are they okay to run or did I get a bad set?
Re: Piston rings - which is which? [Re: DaytonaTurbo] #374031
07/14/09 12:49 AM
07/14/09 12:49 AM
I dont know how they will turn out in actual use but I have yet to see identical top and second rings and I would suspect the assembly line guy grabbed 2 bunches of top rings. To the OP, I just opened a new set of Hastings rings(cast,cast) for you & the ones in the "top" section are rectangular w no chamfer & (for good reason)no dot(wouldn't need one as could go either way) just like the ones in your pic. The 2nd groove ones have a dot w the chamfer on the bottom inside so it would appear(from going thru my ring sets that the other ones in your pic w the dot and the top inside bevel are also top rings and that you have 2 different varieties of top rings. EDIT just now noticed that your non beveled one on the right has a dot whereas my hastings identical top rings do not
Re: Piston rings - which is which? [Re: RapidRobert] #374032
07/14/09 04:06 AM
07/14/09 04:06 AM
London, UK.
P
prothed Offline OP
prothed  Offline OP
P
London, UK.
Thanks for this guys. It does look like I have two sets of top rings - but whether that is by design or accident isn't very clear.
I've been given a link to the manufacturers application guide -
http://www.federalmogul.com/korihandbook/en/section_18.htm
but that implies that either type of ring can be used in either position.....
