Does too much oil slow a car down? #373962
07/13/09 02:17 PM
07/13/09 02:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Just curious what difference the amount of oil ran in a car affects ET.
I generally run 6.5-7 quarts of oil, but currently have 8 in it. just curious what others have found/noted.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Does too much oil slow a car down? [Re: B3422W5] #373963
07/13/09 02:36 PM
07/13/09 02:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If the oil level is high enough to effect windage than I would think yes, How much of an effect in ET who knows every combo is different , Its hard to guess whats goin on in he crankcase @ high rpm
Re: Does too much oil slow a car down? [Re: B3422W5] #373964
07/13/09 02:51 PM
07/13/09 02:51 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
As little oil as it takes to keep the warning lite off. Why did you feel the need to run more oil than your norm?
Re: Does too much oil slow a car down? [Re: B3422W5] #373965
07/13/09 02:53 PM
07/13/09 02:53 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
OK and did it make any difference in your car? I run a quart more than what is recommended for the pan because the external line and filter hold oil also.
Re: Does too much oil slow a car down? [Re: cudabunch] #373966
07/13/09 03:13 PM
07/13/09 03:13 PM
PA
moparacer Offline
moparacer  Offline
PA
Makes a tenth of a second difference in our 4 inch stroke 360...
Too much oil is not a good thing....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Does too much oil slow a car down? [Re: goldmember] #373967
07/13/09 03:20 PM
07/13/09 03:20 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
its an 8 quart pan, i just filled it all the way up this time for some reason, instead of my typical 6.5 to 7 quarts
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Does too much oil slow a car down? [Re: moparacer] #373968
07/13/09 03:20 PM
07/13/09 03:20 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
exactly what it cost me, I run my stuff 1/2-1qt less then advertised
Re: Does too much oil slow a car down? [Re: cudabunch] #373969
07/13/09 03:24 PM
07/13/09 03:24 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
i lost a tenth somewhere, and am guessing having 8 quarts in it is where it went
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Does too much oil slow a car down? [Re: B3422W5] #373970
07/13/09 03:25 PM
07/13/09 03:25 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I did the same thing recently with my new build...I just thought a little extra oil for the new mill would be good insurance until I get to know the motor a little better. I have ~ 9 in it now, I ran 7 qt with the old motor.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Does too much oil slow a car down? [Re: B3422W5] #373971
07/13/09 03:32 PM
07/13/09 03:32 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Easy enough to figure out.Next time out run it again and then pull off the oil filter, dump it and see if it goes faster.
Re: Does too much oil slow a car down? [Re: B3422W5] #373972
07/13/09 03:32 PM
07/13/09 03:32 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
"its an 8 quart pan, i just filled it all the way up this time for some reason, instead of my typical 6.5 to 7 quarts " I run an "8qt" pan and never have over 6 qts in it. At 5qts the warning lite will flicker during braking after a pass. I'm sure different combos have differing requirements,so a little testing would be a good idea.
Re: Does too much oil slow a car down? [Re: FlyFish] #373973
07/13/09 03:34 PM
07/13/09 03:34 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I told you that last wk 1 qrt is worth 1 tenth the test have been done to back it up
Re: Does too much oil slow a car down? [Re: B3422W5] #373974
07/13/09 03:37 PM
07/13/09 03:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not shure about et loss but my car had no issues running 6 qts. in an 8 qt. pan even at 7000+ rpm`s I never lost pressure.....had 75 psi at 7500 rpm`s.
Re: Does too much oil slow a car down? [Re: Thumperdart] #373975
07/13/09 11:11 PM
07/13/09 11:11 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Way back, a guy named Smokey Yunick put a window in an oil pan and observed how fill level affected the rotating assy. He found that the crank & rods are capable of sucking the oil up into the shape of a rope that winds itself around them. It increases the drag on the engine and whips up the oil. The only time I'm close to the full level on a big race pan is for the 1st fire & break-in splash.
On my race motor, there's never more than 6 QT in its 10QT pan, even with my windage tray.
Re: Does too much oil slow a car down? [Re: B3422W5] #373976
07/13/09 11:34 PM
07/13/09 11:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I always run 1 qt down on a big pan
Re: Does too much oil slow a car down? [Re: MR_P_BODY] #373977
07/13/09 11:54 PM
07/13/09 11:54 PM
st.charles,mo.
dodgem1 Offline
dodgem1  Offline
st.charles,mo.
yes ,take a run down the beach,then run down the beach in about a foot of water,i bet you run faster out od the water,same thing
Re: Does too much oil slow a car down? [Re: dodgem1] #373978
07/14/09 12:10 AM
07/14/09 12:10 AM
It seems to me there should be harsher implications of too high oil level. What if the oil foams more, this could potentially cause pressure loss due to aeriation/ foaming
Re: Does too much oil slow a car down? #373979
07/14/09 08:24 AM
07/14/09 08:24 AM
gregsdart Online content
gregsdart  Online Content
A lot depends on rpm, how much is being pushed through the motor, pan depth, type, etc. EVERY situation is different. For your purpose, get a good gauge, and set it up to be very responsive. Some are dampened by using a small hole at the gauge. Then watch what your system does under all conditions. Adjust accordingly.I ruined a lot of bearings till i figured out that the oil pressure "dip" in the traps was a lot worse than the gauge was telling me. An Accusump system can help you if you are going for the least oil in the pan, but can be overkill for most. In my case it is mandatory due to braking forces.
Re: Does too much oil slow a car down? [Re: gregsdart] #373980
07/14/09 11:57 AM
07/14/09 11:57 AM
S Dak
sc5141 Offline
sc5141  Offline
S Dak
I have seen cases when oil gets trapped in the upper part of the motor and have an oil psi drop because there is no oil in the pan. Each motor is a little differant
