Does too much oil slow a car down?
#373962
07/13/09 02:17 PM
07/13/09 02:17 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Just curious what difference the amount of oil ran in a car affects ET.
I generally run 6.5-7 quarts of oil, but currently have 8 in it. just curious what others have found/noted.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Does too much oil slow a car down?
[Re: B3422W5]
#373965
07/13/09 02:53 PM
07/13/09 02:53 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
OK and did it make any difference in your car? I run a quart more than what is recommended for the pan because the external line and filter hold oil also.
[Re: cudabunch]
#373966
07/13/09 03:13 PM
07/13/09 03:13 PM
Posts: 2,513 PA
moparacer
PA
Makes a tenth of a second difference in our 4 inch stroke 360...
Too much oil is not a good thing....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: goldmember]
#373967
07/13/09 03:20 PM
07/13/09 03:20 PM
B3422W5
Portage,michigan
As little oil as it takes to keep the warning lite off. Why did you feel the need to run more oil than your norm?
its an 8 quart pan, i just filled it all the way up this time for some reason, instead of my typical 6.5 to 7 quarts
[Re: moparacer]
#373968
07/13/09 03:20 PM
07/13/09 03:20 PM
Posts: 6,314 The Swamp
MegaDart
The Swamp
exactly what it cost me, I run my stuff 1/2-1qt less then advertised
[Re: cudabunch]
#373969
07/13/09 03:24 PM
07/13/09 03:24 PM
B3422W5
Portage,michigan
i lost a tenth somewhere, and am guessing having 8 quarts in it is where it went
[Re: B3422W5]
#373970
07/13/09 03:25 PM
07/13/09 03:25 PM
Posts: 1,178 Indy
FlyFish
Indy
I did the same thing recently with my new build...I just thought a little extra oil for the new mill would be good insurance until I get to know the motor a little better. I have ~ 9 in it now, I ran 7 qt with the old motor.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: B3422W5]
#373971
07/13/09 03:32 PM
07/13/09 03:32 PM
cudabunch
Wellington, FL
Easy enough to figure out.Next time out run it again and then pull off the oil filter, dump it and see if it goes faster.
[Re: B3422W5]
#373974
07/13/09 03:37 PM
07/13/09 03:37 PM
Thumperdart
State of confusion
Not shure about et loss but my car had no issues running 6 qts. in an 8 qt. pan even at 7000+ rpm`s I never lost pressure.....had 75 psi at 7500 rpm`s.
[Re: dodgem1]
#373978
07/14/09 12:10 AM
07/14/09 12:10 AM
It seems to me there should be harsher implications of too high oil level. What if the oil foams more, this could potentially cause pressure loss due to aeriation/ foaming
#373979
07/14/09 08:24 AM
07/14/09 08:24 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A lot depends on rpm, how much is being pushed through the motor, pan depth, type, etc. EVERY situation is different. For your purpose, get a good gauge, and set it up to be very responsive. Some are dampened by using a small hole at the gauge. Then watch what your system does under all conditions. Adjust accordingly.I ruined a lot of bearings till i figured out that the oil pressure "dip" in the traps was a lot worse than the gauge was telling me. An Accusump system can help you if you are going for the least oil in the pan, but can be overkill for most. In my case it is mandatory due to braking forces.
