70 Charger Power Steering and Brake Questions #373934
07/13/09 01:48 PM
07/13/09 01:48 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
This is a 70 Charger with a 499 stroker.
First off the power steering is ultra touchy...maybe I am conditioned to my late model Dodge truck and this is really not a problem but man o man the power steering seems to have too much assist. Any ideas?
Second is brakes. I think I may have a bad booster. The brakes seem to work fine after any time driving but once the pedal has been pushed a few times in succession it seems to lose stopping power. Almost as though there is not enough vaccum for the booster. Continue driving without having to stop for a shile and it seems tro work fine again. But if it works once and it is a closed system, it should work every time...shouldn't it? I am wondering if a pin hole in the diaphram might cause such an issue.
Any help on either concern is greatly appreciated.
Re: 70 Charger Power Steering and Brake Questions [Re: scoutsr2] #373935
07/13/09 01:50 PM
07/13/09 01:50 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
old PS is not like New PS. and what cam are you running???
Coming soon!!!!
Re: 70 Charger Power Steering and Brake Questions [Re: Mr.Yuck] #373936
07/13/09 02:06 PM
07/13/09 02:06 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
old PS is not like New PS. True but by simply swapping out the steering gear with a stage two or stage three from Firm Feel it can be... and what cam are you running???
Yep Low vacuum either to much cam or not properly turned... There are quite a few options including just tuning or a milder cam or adding an electric vacuum pump...
Re: 70 Charger Power Steering and Brake Questions [Re: Mr.Yuck] #373937
07/13/09 02:22 PM
07/13/09 02:22 PM
Temple, Texas
scoutsr2 Offline OP
scoutsr2  Offline OP
Temple, Texas
Custom Hydraulic.
HP4
238 @ 50
318 lobe lift
1.6 rockers
I specifically asked when building this engine that it have a mild enough cam to handle power brakes and air conditioning. Pretty sure that is not what I ended up with.
Can you guys give me more info on the electric vaccum pump and how it works?
Re: 70 Charger Power Steering and Brake Questions [Re: scoutsr2] #373938
07/13/09 02:31 PM
07/13/09 02:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
With those kinda specs in a 499 I'd expect to be able to get more than enough vacuum to run the brakes... What is your base timing set at? More intial timing will strenghten the vacuum & improve the idle & low speed performance.. But to run more intial you need to limit the total so you don't wind up with 40+ degrees of total timing when the mechanical advance is all in... Typically I try adding more intial without worrying about total at first till I see how much intial the motor wants then I modify the advance slots to limit total to around 34-36..
Re: 70 Charger Power Steering and Brake Questions [Re: scoutsr2] #373939
07/13/09 03:15 PM
07/13/09 03:15 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Did you by any chance upgrade your brakes at all? my 70 Charger had 11x3 drum brakes up front and 10" drums on the rear. I swapped everything from a 75 Disc braked Dart on to the system except for the bigger booster and the proportioning block...I feather could touch the brake pedal and it would lock all 4 corners. Problem went away after a larger booster was installed and the correct prop valve
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
