ANYONE USE S&W 10 POINT CAGE #373655
07/13/09 02:01 AM
07/13/09 02:01 AM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
Has anyone here used a 10 point or more S&W cage. If so do you have any pictures of the fit. Especially the main hoop and halo bar at the roof.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373656
07/13/09 03:33 AM
07/13/09 03:33 AM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
S&W was used in my 65 Sport fury. 10 point cage,
ladder bar and coil over also. I'll look for some
inside picts and PM them to you. There stuff fits
real good.
Snap your neck, mega G-force launch, is all I want!
Re: ANYONE USE S&W 10 POINT CAGE [Re: BDS871Cuda] #373657
07/13/09 07:19 AM
07/13/09 07:19 AM
alabama
mopar addict
mopar addict
alabama
Thanks. I would appreciate the pictures.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373658
07/13/09 07:39 AM
07/13/09 07:39 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Here's what you can see of my S&W cage...
Re: ANYONE USE S&W 10 POINT CAGE [Re: 70HemiGTX] #373659
07/13/09 07:40 AM
07/13/09 07:40 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
another one. I don't have any of the hailo hoop. I can try to get one though.
Re: ANYONE USE S&W 10 POINT CAGE [Re: 70HemiGTX] #373660
07/13/09 08:46 AM
07/13/09 08:46 AM
alabama
mopar addict
mopar addict
alabama
The reason I ask is because my cage ( comp engineering ) in the center of the car is about 3 1/4" from the roof, that just seems too low for me. Also the halo bar is about 4" from where the door seal is from the side of the car. If I try to center my seat with the steering wheel my helmet will be touching the halo bar. I am just not happy with it and have learned a lot a little too late about some things but I am willing to bite the bullit and put in another cage before I get too far with my project. Just looking to see what will fit best. Any comments and opinions welcome.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373661
07/13/09 10:06 AM
07/13/09 10:06 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
check out chris alstons chassis works, they have very nice cages.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373662
07/14/09 01:14 AM
07/14/09 01:14 AM
I have the same problem with the halo bar so I did some mods in vain so now I got some more tube and having Killer Customs bend me a new halo bar. Dropped it off today ready for tomorrow morning. I have the same kit from Comp Eng. and nothing fit and I am adding more bar. When I modified the halo I had to widen it 9" and the new one will be 9" wider than what was in the box, I ordered for a 69 b-body but must have been made for a compact.
Re: ANYONE USE S&W 10 POINT CAGE [Re: 68valiant68] #373663
07/14/09 07:29 AM
07/14/09 07:29 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
Here is mine Chris Alstons
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: ANYONE USE S&W 10 POINT CAGE [Re: Kam*Kuda] #373664
07/14/09 07:30 AM
07/14/09 07:30 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
2
1654.5 Mustang
1955 Land Rover
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373665
07/14/09 10:00 AM
07/14/09 10:00 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
did not care for my cage from S&W.
No halo bar, side bars and a tube across front.
had to compromise fit of side bars.
would much prefer a tight fitting halo now after the fact.
Re: ANYONE USE S&W 10 POINT CAGE [Re: 70HemiGTX] #373666
07/14/09 01:23 PM
07/14/09 01:23 PM
alabama
mopar addict
mopar addict
alabama
Called S&W today and they sent me some measurements of the cage they build to fit my car. I compared the measurements to the cage I have and also to my car. It is going to fit like a glove so I went ahead and ordered it. The cages are completely different, S&W halo bar is 5" wider and the main hoop is way taller and will fit to the roof.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373667
07/14/09 06:23 PM
07/14/09 06:23 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My halo bar and main hoop are up out of the way also. S&W installed mine. The front runners are also out of the way. The only issue is I should have had them install a swing out bar. I'm not quite as flexible as I used to be.....
Re: ANYONE USE S&W 10 POINT CAGE [Re: 70HemiGTX] #373668
07/14/09 11:53 PM
07/14/09 11:53 PM
alabama
mopar addict
mopar addict
alabama
That is one thing I have been considering doing when I put this cage in. Haven't made up my mind yet. Cage probably won't be here til sometime next week anyway, so I have a little time to think on it.
Re: ANYONE USE S&W 10 POINT CAGE [Re: mopars rule] #373669
07/15/09 07:35 AM
07/15/09 07:35 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Mine is a S&W rool bar with a cage conversion and frunt bars it becomes a 12 point, all from S&W. I installed it.
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
