8 3/4 bearing replacment #373218
07/12/09 02:52 PM
07/12/09 02:52 PM
weymouth,mass.
meepmeep70 Offline OP
weymouth,mass.
where are you guys buying from? and are you using green bearings or is there a better choice? i thought there was a post on mopar performance but can;t find it. thanks for any tips. Darren
Re: 8 3/4 bearing replacment [Re: meepmeep70] #373219
07/12/09 02:57 PM
07/12/09 02:57 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Which bearings carrier or axle?
Re: 8 3/4 bearing replacment [Re: meepmeep70] #373220
07/12/09 03:09 PM
07/12/09 03:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
This subject often leads to heated debate, the stock tapered bearing is superior to the Green bearing but many use the Greens because they're too lazy to learn how to adjust the tapered bearings. (flame suit on)
Forum member Doctor Diff has both.
Re: 8 3/4 bearing replacment [Re: John_Kunkel] #373221
07/12/09 04:55 PM
07/12/09 04:55 PM
BDW Online content
BDW  Online Content
I learned what he said the hard way.
Bought all new stuff from Dr. Diff, gave it all to the guy rebuilding my Dana.
When I pick it up he says, "I had to put green bearings in, the factory stuff is too difficult"
Anyone want to buy a set of axle bearing & adjusters cheap?
Re: 8 3/4 bearing replacment [Re: John_Kunkel] #373222
07/12/09 05:19 PM
07/12/09 05:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Unless you are running a spool Greens shouldn't be anything but a last resort .
Re: 8 3/4 bearing replacment [Re: John_Kunkel] #373223
07/12/09 07:29 PM
07/12/09 07:29 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Ain't that the truth? and the thing oncee they are adjusted it isn't something that has to be repeated in the forseeable future.
Why do you want to change bearings? If they aren't galled or pitted clean them up and pack them with a good wheel bearing compatable grease, install new inner axle seals, put the axles in, adjust the endp play and button it up. http://www.moparts.org/Tech/Archive/axle/12.html
