Re: 727 Solid Trans Mount
[Re: RaceCarRegistry]
#372503
07/11/09 04:24 PM
07/11/09 04:24 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Anyone make a good, race only, 727 steel (solid) replacement-type trans mount ? Thanks, Reed in Neb.
for what year?
#372506
07/11/09 04:33 PM
07/11/09 04:33 PM
blownzoom440
ELYRIA,OH
would you be interested in cutting a failsafe mount to fit the old rubber style cross member?i had some sitting around is why i did it.
Post deleted by Defbob
[Re: rebel]
#372508
07/11/09 06:57 PM
07/11/09 06:57 PM
[Re: jake4cars]
#372510
07/12/09 05:56 AM
07/12/09 05:56 AM
Posts: 296 CT
turbocolt2.4L
CT
i have solid mounts on colt engine/trans no broken tails yet (knock on wood) just some loose bolt here and there loctite will be your best friend
[Re: turbocolt2.4L]
#372511
07/12/09 03:01 PM
07/12/09 03:01 PM
Posts: 25,910 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Solid mounting makes the trans part of the chassis structure, less of a problem if the chassis is very rigid but solid mounting in a flexy chassis can cause case flex and broken parts.
[Re: John_Kunkel]
#372512
07/12/09 03:04 PM
07/12/09 03:04 PM
[Re: Jeremiah]
#372517
07/12/09 09:03 PM
07/12/09 09:03 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I'd get a poly mount from Imperial Services.
But, he needs it before next year...
Reed, if ya need/want it get it directly from John Cope.
[Re: dusturbd340W5]
#372518
07/12/09 09:33 PM
07/12/09 09:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
So is it cool to solid mount the trans tail in a full tube chassis car with front and mid motor plates?
I have a full tube chassis with a front and mid motor plate with a solid trans mount and have had zero problems so far it 60 fts at 1.40 running 6.5x in the 1/8 pulling the fronts about a ft off the ground.
I'm gonna say you;ve been lucky so far.... ALL chassis's flex, its just a matter of how much and when they flex the engine and trans dont stay on the same center line.... remember your old math class... 2 points are in a line... add a 3rd and it doesnt mean its on the same line, specially when you add flex
[Re: dusturbd340W5]
#372521
07/15/09 10:14 AM
07/15/09 10:14 AM
Just and FYI but I ordered an early B-body to late trans poly conversion mount from Schumacher and had it in 2 days. It was the Imperial sourced mount. Cope is good too.
