Re: 68 Charger R/T help
[Re: primlinstc]
#372220
07/11/09 04:51 AM
07/11/09 04:51 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
I bought a 68 R/T 4 speed car in the mid 70s. it had a Dana 60 in it. are you sure you bought a R/T ?
I am truckless..
[Re: 340SHORTY]
#372221
07/11/09 04:59 AM
07/11/09 04:59 AM
Posts: 4,247 Alabama
BigMoneyLewis
Alabama
The 4-speed means you also had a Dana from the factory when you are talking about L code B bodies . BUT, without a fender tag or buildsheet , are you even sure it was originally a 4-speed car ? You might contact Wayne Wooten, who runs the Dodge Charger registry, and see if he by chance knows anyone who might have a copy of your buildsheet . It's a long shot but worth looking into. Greg Wards Classic Car Radio Repair Specializing in restoration and sales of Mopar A B E body radios We can restore YOUR radio usually in less than 14 days Visit our NEW website.. http://www.wardsclassiccarradiorepair.comgregward@mchsi.comphone 256-852-0955
[Re: primlinstc]
#372222
07/11/09 05:39 AM
07/11/09 05:39 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Some things to look for regarding the 4-speed. Does it have the big square/blocky rubber bumpers on the rear axle hump area of the rear frame rails? Also, does it have the pedal support bracket in the firewall? This is located to the outside side of the master cylinder / brake booster. You will see an about 6 inch vertical bracket attached to the firewall with two studs going through.
Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
