Power inverter? #371268
07/09/09 07:00 PM
07/09/09 07:00 PM
Illinois
Mopar_Ray Offline OP
Illinois
Would a 750 watt power inverter be enough to power a battery charger. I'v been thinking about buying a small generator to charge between runs, but was wondering if a power inverter on the tow vehicle would be enough?
Re: Power inverter? [Re: Mopar_Ray] #371269
07/09/09 07:26 PM
07/09/09 07:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It would have to be a really small charger, but you
might get away with a 1000 watt.... you would have
to check the draw on the charger you want to use
Re: Power inverter? [Re: MR_P_BODY] #371270
07/09/09 09:23 PM
07/09/09 09:23 PM
Illinois
Illinois
Small charger...1.5 amp...?
Re: Power inverter? [Re: Mopar_Ray] #371271
07/09/09 09:30 PM
07/09/09 09:30 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes, 100 watts is about 1 amp.
Kind of weird, start with 12V turn it into 120V and then back to 12V.
Re: Power inverter? [Re: Mopar_Ray] #371272
07/10/09 10:01 AM
07/10/09 10:01 AM
Sydney, Australia
B-STUNG Offline
B-STUNG  Offline
Sydney, Australia
Never tried it, but I think it will work.
A 12V charger with a maximum 4 amp output, even with only a 70% efficiency and a 70% pf, will be well below 150W.
Re: Power inverter? [Re: B-STUNG] #371273
07/10/09 11:08 AM
07/10/09 11:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I called one of the bigger power inverter company's and asked a tech the same question. I wanted to put one in the race car trailer and power some lights and possibly charge the race cars battery. He said it would take a large bank of batteries. I did put a 1000 watt in the trailer to run the lights,practice tree,fan,and a few other things. Its nice not having to start the generator every time you need power.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
