Closing holes in frame #370861
07/09/09 10:30 AM
07/09/09 10:30 AM
New Hampshire
W
whitemtnelf Offline OP
W
New Hampshire
Has anyone sealed up the holes in their frame to stop mice from being able to get in there and make nests?
Re: Closing holes in frame [Re: whitemtnelf] #370862
07/10/09 01:29 AM
07/10/09 01:29 AM
Sonora, CA
68X426 Offline
68X426  Offline
Sonora, CA
Try some steel wool. It's easy to work into small spots and mice just won't mess with it. Can even paint it I suppose.
The 12 Scariest Words in the English Language: We are here from the Government and we want to help you. 1968 Plymouth Road Runner, Hemi and much more 1968 Dodge Charger, 318 and not much else 1958 Dodge Pick Up, 383 and loud 1966 Dodge Van, Slant 6 and cool
Re: Closing holes in frame [Re: 68X426] #370863
07/10/09 08:47 AM
07/10/09 08:47 AM
New Hampshire
W
W
New Hampshire
Thanks for the suggestion. I was thinking about filling them with the spray foam insulation that I use to fill cracks around the house.
Re: Closing holes in frame [Re: whitemtnelf] #370864
07/10/09 09:02 AM
07/10/09 09:02 AM
Spring, Texas
RedFish Offline
super street
RedFish  Offline
super street
Spring, Texas
That stuff will cause it to hold moisture and then rust.
Re: Closing holes in frame [Re: RedFish] #370865
07/10/09 09:11 AM
07/10/09 09:11 AM
New Hampshire
W
W
New Hampshire
That was a close one! Thanks for the heads up. How about welding them closed?
The reason I'm pursuing this is that I had huge mice nests in the frames and they stink really really badly.
Re: Closing holes in frame [Re: whitemtnelf] #370866
07/10/09 09:44 AM
07/10/09 09:44 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I would try finding a rubber body plug that would fit in the holes before I started welding.
Have you tried mothballs? I have always put mothballs in an aluminium foil pan and shoved it under the car over the winter.
Re: Closing holes in frame [Re: burdar] #370867
07/10/09 09:56 AM
07/10/09 09:56 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Easy to remove, too.
Re: Closing holes in frame [Re: whitemtnelf] #370868
07/10/09 09:59 AM
07/10/09 09:59 AM
Chicago illinois
ChinooK440 Offline
ChinooK440  Offline
Chicago illinois
I,d use some snap in steel hole plugs if you can find the right size for the holes you want to plug up. Most better hardware stores and industrail supply houses have them in a variety of sizes.
Re: Closing holes in frame [Re: ChinooK440] #370869
07/10/09 01:45 PM
07/10/09 01:45 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
I would not plug all the holes... some of them allow water to get out of the frame, be sure at least one of the bottom holes is clear so moisture can get out...
Re: Closing holes in frame [Re: 6T6Cuda] #370870
07/10/09 03:20 PM
07/10/09 03:20 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Yep, the holes are there for a reason; don't block them. Instead, deal with the mice with mothballs, traps and poison.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Closing holes in frame [Re: DPelletier] #370871
07/10/09 05:22 PM
07/10/09 05:22 PM
Bloomington, Illernoise
cptn60 Offline
cptn60  Offline
Nothing beats a good Cat. Or twenty.
This space available for rent
Re: Closing holes in frame [Re: whitemtnelf] #370872
07/10/09 11:15 PM
07/10/09 11:15 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Well the problem is that mice have a malluable skull and can squeeze their head and a body into holes the size of a dime...wow. They can also chew a hole through concrete if they wanted. So if they want in, they will get in. My suggestion, if parking in a garage, would be to spray the entire floor with bug killer. I did this a while back and see no bugs, no mice, no nothing.
Re: Closing holes in frame [Re: moparmojo] #370873
07/11/09 12:08 AM
07/11/09 12:08 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The guy I rent winter storage from lets a cat roam around in there, never any sign of mice. As extra protection I also spread drier sheets all over the inside of the car and pour mothballs around the tires. Never any problems yet.
