oil pressure dropping on the launch? #370834
07/09/09 10:08 AM
07/09/09 10:08 AM
somewhereintheswampsofjersey
1swingin Offline OP
1swingin  Offline OP
When i was at the track last night i noticed when i left the line my oil pressure drop! It picked back up and didnt go 2 low but i didnt like it. Is there anyway to cure the problem without pulling the motor and switching to a baffled oil pan? Also,i run a six pack pan. I plan on freshining up the motor at the end of the year but i just want 2 get it through the rest of the season without hurting it! Any input would be greatly appreciated!
Re: oil pressure dropping on the launch? [Re: 1swingin] #370835
07/09/09 11:12 AM
07/09/09 11:12 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
How many litres (sorry, quarts ) are you running? I always ran 6 in a stock pan to be safe.
Re: oil pressure dropping on the launch? [Re: RemCharger] #370836
07/09/09 03:39 PM
07/09/09 03:39 PM
1swingin Offline OP
1swingin  Offline OP
I run a six pack pan that i was told holds seven but i switched 2 a bigger oil filter. I havnt noticed the problem until i recently got the car 2 hook better. Any sugestions would be appreciated! Thanks 4 the help! 383s rule!
"I aint here on buisness baby,Iam only here for fun"
Re: oil pressure dropping on the launch? [Re: 1swingin] #370837
07/09/09 03:51 PM
07/09/09 03:51 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Add baffles to the pan so you don't get so much oil slos h on launch.
Re: oil pressure dropping on the launch? [Re: 1swingin] #370838
07/09/09 03:51 PM
07/09/09 03:51 PM
Florida STAYcation
MasterDeBaTeR ! Offline
The village idiot's idiot
Florida STAYcation
There are no baffles in the pan you are running now ? ... a TRUE six-pack pan should have good baffling in it.
If you are having OP probs with this set-up .. you BEST put a good pan on it or you WILL hurt-it ferr-sure.
Re: oil pressure dropping on the launch? [Re: MasterDeBaTeR !] #370839
07/09/09 05:07 PM
07/09/09 05:07 PM
1swingin Offline OP
1swingin  Offline OP
I guess i will pull it out and bafle it up! Thanks guys!
Re: oil pressure dropping on the launch? [Re: 1swingin] #370840
07/09/09 05:17 PM
07/09/09 05:17 PM
Florida STAYcation
Florida STAYcation
DO IT ..... without baffles ...all that oil is up in the back two cylinders KILLING the horsepower.
Getting a good oiling system is one of the best investments you can make.
