Re: Roll cage opinion
[Re: ]
#370810
07/09/09 09:51 AM
07/09/09 09:51 AM
Posts: 52,972 Romeo MI
MR_P_BODY
In my opinion the tech guy wont like it.... that angle right before the main hoop is a weak point, why didnt you go straight to the main hoop
[Re: MR_P_BODY]
#370811
07/09/09 09:55 AM
07/09/09 09:55 AM
The top halo bar is wider than the main hoop at that point so I had to turn a piece down and out.
[Re: ]
#370812
07/09/09 10:01 AM
07/09/09 10:01 AM
MR_P_BODY
What I would do is put a piece of tubing from the angle to the corner of the main hoop(I.m sure that would fly)
[Re: MR_P_BODY]
#370813
07/09/09 10:08 AM
07/09/09 10:08 AM
By that due you mean leaving as is and adding a tube to the upper part of the main hoop as a gusset.
[Re: 52savoy]
#370816
07/09/09 01:17 PM
07/09/09 01:17 PM
MR_P_BODY
Yeah..you need to find a shop that will bend new bars to tie in to the main hoop. I wouldn't have cut them off because I weakens it too much. A small bend would have got them headed back to the hoop. Harbor Freight sells cheapie tubing benders FYI.
That would be the best option and that way you would know it would pass
[Re: MR_P_BODY]
#370817
07/09/09 01:55 PM
07/09/09 01:55 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I know the guy that techs at my local track I don't think he would pass it like it is.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#370818
07/09/09 02:02 PM
07/09/09 02:02 PM
Thanks guys. I guess I just have to do it again. Bad part is its two to three weeks to get new bar.
Post deleted by Defbob
[Re: ]
#370819
07/09/09 02:04 PM
07/09/09 02:04 PM
#370820
07/09/09 02:16 PM
07/09/09 02:16 PM
[Re: ]
#370821
07/09/09 03:38 PM
07/09/09 03:38 PM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
dont even try to run that
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: jamesc]
#370825
07/09/09 11:32 PM
07/09/09 11:32 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
2 pieces butt welded together like that without proper reinforcement will definitely not pass. Rule book is pretty clear about how and where that can be done.
[Re: 68valiant68]
#370827
07/10/09 12:52 AM
07/10/09 12:52 AM
Thanks to all for the replies, I will be changing the top halo bar.
