Roll cage opinion #370809
07/09/09 09:43 AM
07/09/09 09:43 AM
Anonymous OP
Anonymous OP
I am in the middle of installing the roll cage in my 69 coronet and before I go any further I would like some opinions on wether this section I have done would pass a tech inspection. I posted some pics of the section and any thoughts would be very helpful. Thanks,
Robert.
Re: Roll cage opinion [Re: ] #370810
07/09/09 09:51 AM
07/09/09 09:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
In my opinion the tech guy wont like it.... that
angle right before the main hoop is a weak point,
why didnt you go straight to the main hoop
Re: Roll cage opinion [Re: MR_P_BODY] #370811
07/09/09 09:55 AM
07/09/09 09:55 AM
Anonymous OP
Anonymous OP
The top halo bar is wider than the main hoop at that point so I had to turn a piece down and out.
Re: Roll cage opinion [Re: ] #370812
07/09/09 10:01 AM
07/09/09 10:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What I would do is put a piece of tubing from the
angle to the corner of the main hoop(I.m sure that
would fly)
Re: Roll cage opinion [Re: MR_P_BODY] #370813
07/09/09 10:08 AM
07/09/09 10:08 AM
Anonymous OP
Anonymous OP
would fly)
By that due you mean leaving as is and adding a tube to the upper part of the main hoop as a gusset.
Re: Roll cage opinion [Re: MR_P_BODY] #370814
07/09/09 10:10 AM
07/09/09 10:10 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
do you have any chassis shops around you? if so, have someone custom bend the front bars. make it 3 pcs one one on each side, one in the middle at the roofline by windshield to tie it in. cutting and welding so close to a rollover point, I wouldnt do it.
Re: Roll cage opinion [Re: ] #370815
07/09/09 12:22 PM
07/09/09 12:22 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Yeah..you need to find a shop that will bend new bars to tie in to the main hoop. I wouldn't have cut them off because I weakens it too much. A small bend would have got them headed back to the hoop. Harbor Freight sells cheapie tubing benders FYI.
Re: Roll cage opinion [Re: 52savoy] #370816
07/09/09 01:17 PM
07/09/09 01:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That would be the best option and that way you would
know it would pass
Re: Roll cage opinion [Re: MR_P_BODY] #370817
07/09/09 01:55 PM
07/09/09 01:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I know the guy that techs at my local track I don't think he would pass it like it is.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Roll cage opinion [Re: dusturbd340W5] #370818
07/09/09 02:02 PM
07/09/09 02:02 PM
Anonymous OP
Anonymous OP
Thanks guys. I guess I just have to do it again. Bad part is its two to three weeks to get new bar.
Post deleted by Defbob [Re: ] #370819
07/09/09 02:04 PM
07/09/09 02:04 PM
Anonymous OP
Anonymous OP
Re: Roll cage opinion #370820
07/09/09 02:16 PM
07/09/09 02:16 PM
Anonymous OP
Anonymous OP
Re: Roll cage opinion [Re: ] #370821
07/09/09 03:38 PM
07/09/09 03:38 PM
Lebanon,IN
mr2performance Offline
Lebanon,IN
dont even try to run that
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Roll cage opinion [Re: mr2performance] #370822
07/09/09 03:40 PM
07/09/09 03:40 PM
Orlando Florida
blown572dart Offline
Orlando Florida
Re: Roll cage opinion [Re: ] #370823
07/09/09 09:37 PM
07/09/09 09:37 PM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
I am not a chassis expert, nor have I even tried installing a cage but you might want to get your local NHRA chassis tech to come by and explain to you what is acceptable and what is not. I would do this before ordering anything as you might have to chuck it too. Just my
Re: Roll cage opinion [Re: ] #370824
07/09/09 09:45 PM
07/09/09 09:45 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
hard to say how to fix it with out actually being there to see it but that won't pass.
Re: Roll cage opinion [Re: jamesc] #370825
07/09/09 11:32 PM
07/09/09 11:32 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
2 pieces butt welded together like that without proper reinforcement will definitely not pass. Rule book is pretty clear about how and where that can be done.
Re: Roll cage opinion [Re: CMcAllister] #370826
07/09/09 11:37 PM
07/09/09 11:37 PM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
check chris alstons chassisworks for cage. they seem to have a nicer setup. just remember, car can be replaced, you cant. so build as safe as possible. my cage will cert to 8.50 or slower and i run 10.50's. but i am safe.
Re: Roll cage opinion [Re: 68valiant68] #370827
07/10/09 12:52 AM
07/10/09 12:52 AM
Anonymous OP
Anonymous OP
Thanks to all for the replies, I will be changing the top halo bar.
