Page 3 of 6 1 2 3 4 5 6
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370419
07/10/09 11:11 AM
07/10/09 11:11 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
pull the drivers side valve cover, start it up and see if there's any valves either stuck open or not opening (wiped cam)
2017 Grand Cherokee Overland
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: dave571] #370420
07/10/09 06:47 PM
07/10/09 06:47 PM
Laurens, SC
Radio Joe Offline OP
Laurens, SC
Broken intake valve spring is a possibility. The dampener and reminants of the spring would keep the valve closed and operating at starter speed. or turning over by hand.
Then when you run it, it'll bounce. Push on the rockers by hand. If you can move a valve up and down, you know what it is.
FWIW, I've seen it more than once.
I think this may be it!
I pulled the drivers side valve cover whiel the engine was hot and pushed (with a glove on) on the rockers- I could get almost ALL of them to move atleast 1/8 of an inch without too much effort.
I have exp with cehvy but this is my first Mopar engine. On a chevy you cant push springs like that. If its the same on the Mopar then we may have found it.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370421
07/10/09 06:54 PM
07/10/09 06:54 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
Is it the lifters that you are getting to move, or the valve springs?
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparJ] #370422
07/10/09 06:57 PM
07/10/09 06:57 PM
Laurens, SC
Laurens, SC
Its for sure the spring/valve moving. not the lifter. the valve is closed and I push on the rocker above it and it pushes the valve open
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370423
07/10/09 07:30 PM
07/10/09 07:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
It doesn't surprise me that you can do this. Stock 318 springs are pretty wimpy and especially with age. I don't feel that this is our problem though. It may cause a high RPM miss do to float but idle should be uneffected. Also it would not effect the whole side.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparforLife] #370424
07/10/09 08:27 PM
07/10/09 08:27 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
The ONE thing that's common on all the driver's side cylinders but not with the passenger's side is the exhaust pipe leading to the Y.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: FuryUs] #370425
07/10/09 08:42 PM
07/10/09 08:42 PM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
Vacuume issue! Power brakes? If so check the line. If not you may have an internal vacuume leak on the intake gasket. A V8 will not run on 4 cylinders on the highway. Pull all 4 plugwires and try to drive it.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370426
07/10/09 09:06 PM
07/10/09 09:06 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I'm totally reaching but...
Is it possible that the valves are tight on just that head?
Tight enough so when the lifters are pumped up the valves are not closing yet when you do a compression check the valves don't pump up enough to show up as bad compression?
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: HealthServices] #370427
07/10/09 09:09 PM
07/10/09 09:09 PM
Upper Midwest
Upper Midwest
My question is - Did this thing run good at one time and just st art this?? What did you do to the engine prior to it doing this? Did you change anything??
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparforLife] #370428
07/11/09 12:31 AM
07/11/09 12:31 AM
Laurens, SC
Laurens, SC
It doesn't surprise me that you can do this. Stock 318 springs are pretty wimpy and especially with age. I don't feel that this is our problem though. It may cause a high RPM miss do to float but idle should be uneffected. Also it would not effect the whole side.[/qoute]
Well CRAP I was hoping this was it... I did think it would effect it more at higher rpms but was hoping...
I checked the exhaust- no obstructions.
Someone on the H.A.M.B suggested an intake vac leak in the valley. I changed the intake gaskets. The intake didnt look machined or warped but... How would I check for a leak under the intake???
I had major carb problems- bent parts from a previous owner. After getting it fixed it ran okay. Not much low end power but seemed fairly smooth. Only a slight miss that was very hard to hear. It started getting worse for no reason at all. When I started looking into it, thats when I found the 4 cyls not working...
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370429
07/11/09 07:41 AM
07/11/09 07:41 AM
Upper Midwest
Upper Midwest
Hey Joe: Tray as one person above said. Pull all for effected wires at one time, try move it. See if they are really totally missing.
I know that you have checked and re checked this too, but rtrcrck the firing order and remember that the wires go clockwise around the cap.
Check your egr valve.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparforLife] #370430
07/11/09 09:27 AM
07/11/09 09:27 AM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Ok I wasnt going to chime in here as I really had no answer to what your problem might be,but after a little thinking here is my In your first couple posts you indicated that the left bank wasnt working at all, you said that you put a plug in the wire and checked for spark and had it! So what makes you think that the whole drivers side isnt working? If the plugs are firing and correctly then the cylinders are working in that aspect. All the responses to the fact of a vaccum leak and bad carb are not going to be the answer as that would affect how the whole engine operates not just 1 bank. I had a 72 Firebird many years ago that I did a tune up on, the car fired right up but upon revving the motor it had a miss and ran rough,well guess what, I had left all the left side wires laying across the top of the motor. I was amazed it ran at all with only 4 cylinders firing. You said it ran fine at higher RPM's. I guess if the motor has sat for any amount of time then the springs that were compressed might not be closing those valves properly. Or another situation could be the use of unleaded gas has buried the exhaust valves into the seats causing a loss of compression??
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparforLife] #370431
07/11/09 04:59 PM
07/11/09 04:59 PM
Laurens, SC
Laurens, SC
I have been giving this alot of thought- One thing I thought of is since shorting the drivers side ires doesnt effect idle I thought what is I pull all the pass side wires and see if it still runs. I know it will if i pull all the drivers side but I think it will die if I pull all the passenger side wires....
I'll try both ways and let you know what I find.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370432
07/12/09 01:05 PM
07/12/09 01:05 PM
Laurens, SC
Laurens, SC
Okay here is the results of my latest test.
I shoved small wires between the wire and spark plug boot at the spark plug on the bad side then started the engine. I shorted each spark plug starting at #1. first I checked that a spark jumped from the ground wire to the wire I stuck into the wire. then I shorted the wire. with cyls 1,3,5 and 7 shorted there is no change in idle (rough). Then I put the car in gear- Idles the same as before (Rougher then not in gear).
Then I took the car down the driveway. There is a bog but if I flutter the gas pedal it will go. It defintiely runs worse. So that shows that the drivers side cyls are doing SOMETHING above idle.
Next I shut the egine off and inserted the short wires into the pass side splug wires at the spark plug. Stated the car and began shorting wires one by one just as I did on the drivers side (first checking a spark jumped, then shorting it). shorting cyl #2 made the idle get rougher, shorting #4 made it even rougher, shorting 6 was even rougher and when I shorted #8 the engine died. It would not restart like this.
So engine is running at above idle (I would say around 2k rpm I dont feel a miss anymore) but the drivers side is still the problem.
Can someone post a short video of a spark plug firing from their engine. The spark I am getting to jump is orange in color and I would expect witht he coil and ignition system I have that the sprk would be bigger. Maybe not.
I was also posting about this problem over on the H.A.M.B but they have given up on me- Told me to drive it like is or replace the engine
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370433
07/13/09 12:55 PM
07/13/09 12:55 PM
Laurens, SC
Laurens, SC
And to answer the above question about head temp- its hard to tell- head feels same temp BUT if I start it cold and let it warm up while idling in the driveway the passenger side exhaust manifold gets alot hotter than the drivers side.
I can touch the manifold for a second and when I pull my finger away it starts to burn still- On the drivers side I cant hold my finger on it, but if I just touch it for a second like on the pass side, my finger doesnt burn- just can tell its hot.
Any other ideas? Im thinking of pulling the head this weekend and inspecting everything- Anyone think its NOT a good idea?
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370434
07/13/09 01:13 PM
07/13/09 01:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
orange seems like a weak sprk. You wnat a nice blue jolt. What are your plugs gapped at/ I'd think .035-.040 should work. Try a new "hot" coil.
Coming soon!!!!
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Radio Joe] #370435
07/13/09 03:36 PM
07/13/09 03:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Did you try up to this point, slowly covering the top of carb with your hand while it's idling, to see if it smooths out and rpms come up?
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: Mr.Yuck] #370436
07/13/09 03:43 PM
07/13/09 03:43 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
I am tending to think that this may be electronic or ignition related.
Is this a points type ignition or electronic?
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: buildanother] #370437
07/13/09 03:44 PM
07/13/09 03:44 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
Also something to try to help pin point possible vacuum or carb issues.
Re: 318 only running on 4 cylinders HELP!!!!!! [Re: MoparJ] #370438
07/13/09 04:26 PM
07/13/09 04:26 PM
Laurens, SC
Laurens, SC
I checked the spark on my wifes car (4 cyl but...) and they look similar. I wouldve expected better from the HEI distributer but. So I guess spark is okay.
I did try to cover the carb slowly with my hand- Doing this speeds it up a little but still same reaction when shorting the plug wires. I expected it to speed up a bit but it doesnt smooth out at all. can still hear a miss.
A guy at work suggested tighening the rockers a bit more. Even if lash is good, if the tips of the valves or pushrods are worn it may not be openong correctly. I'll give it a try but will only run it long enough to see if it helps.
