? many passes ? "running the valves" in your racecar? #369974
07/08/09 01:16 PM
07/08/09 01:16 PM
mikemotorhead Offline OP
super street
super street
I like to change the oil every 20-25 passes and run the valves at the same time. Overkill???
Mike
Re: ? many passes ? "running the valves" in your racecar? [Re: mikemotorhead] #369975
07/08/09 01:41 PM
07/08/09 01:41 PM
Chicago,Illinois
N
nosboy Offline
nosboy  Offline
N
Chicago,Illinois
I like changing the oil more often than that!!! As far as doing the valves,,,once their done,, they're done!! If I check them and they are allright,, WHY BOTHER???
Re: ? many passes ? "running the valves" in your racecar? [Re: mikemotorhead] #369976
07/08/09 02:32 PM
07/08/09 02:32 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Mike
About the same for oil changes.
I tend to check the lash more frequently after a rebuild, like before a meeting. If you use the parts in the places they originally came from then I've found the lash settles down really quickly. Once they've settled I leave them 'till season end or 'till I break something and the pattern starts again.
Re: ? many passes ? "running the valves" in your racecar? [Re: mikemotorhead] #369977
07/08/09 03:04 PM
07/08/09 03:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mike
I change oil twice a season(about 55 passes maybe more
per change)
and I check the lash on my roller about once a year...
hasnt changed
Re: ? many passes ? "running the valves" in your racecar? [Re: MR_P_BODY] #369978
07/08/09 03:25 PM
07/08/09 03:25 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
About the oil change interval for me, too, 20-25 runs. I admit it might be a bit excessive, but I'm anal about that, and it's worked, so why mess?
I've got 15 passes on this oil, and will probably change it after the Beaver Nostalgia Nats this weekend.
As far as the valves, I go over them the beginning of the season and let it go.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: ? many passes ? "running the valves" in your racecar? [Re: Steve1118] #369979
07/08/09 03:27 PM
07/08/09 03:27 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
I use brad Penn oil so i go a little longer on it. As far as valves, they are usually a first indicator of something going wrong. Ounce the valve train stabilizes they rarely move. ALot of times nothing gets adjusted, just go in and check and make sure all is good in the hood.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: ? many passes ? "running the valves" in your racecar? [Re: mikemotorhead] #369980
07/08/09 03:41 PM
07/08/09 03:41 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Mobil 1 20-25 passes. Valve covers off to check pushrod tips,rocker alignment,oiling. Big spring pressures should be looked at,might as well check lash. SS/AH guys do it every 3-4 passes.
The little old lady from Pasadena is back!
Re: ? many passes ? "running the valves" in your racecar? [Re: Barnstorm] #369981
07/08/09 03:57 PM
07/08/09 03:57 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I change the oil once or twice a season...but I don't get to the track as often as I would like (probably less than 40 passes on the oil). Valves, once at the begining...then again if if starts acting or sounding weird.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: ? many passes ? "running the valves" in your racecar? [Re: FlyFish] #369982
07/09/09 12:36 AM
07/09/09 12:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well you wanna talk anal I guess that is me. We check the lash pretty much after EVERY trip to the track. I usually run the oil for no more than 20 passes or so, never at the track but when we come back froma race and are in that area.
Re: ? many passes ? "running the valves" in your racecar? [Re: Al_Alguire] #369983
07/09/09 09:31 AM
07/09/09 09:31 AM
NC
440Jim Offline
440Jim  Offline
NC
I put new oil in at the start of the season (March).
Run that until July or 50-60 passes. Then store the car over the winter with fresh oil too. If I race a lot, I will change it again during the season (50-60 passes).
I check the valve lash every couple months, but it doesn't need it. A new build requires checking it every race day until I am sure nothing is changing.
Re: ? many passes ? "running the valves" in your racecar? [Re: Al_Alguire] #369984
07/09/09 09:40 AM
07/09/09 09:40 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
We have our valve covers off at least twice per race. A big lash on one valve means something's not right. We've caught early some pretty serious issues this way. Two races ago we had a tip come off of a titanium valve and the rocker had begun to eat into the stem. We got it before it became a BIG deal. Oil change? We take our motor apart several times per season so the oil get's changed then.
Re: ? many passes ? "running the valves" in your racecar? [Re: BobR] #369985
07/09/09 11:05 AM
07/09/09 11:05 AM
super street
super street
"We take our motor apart several times per season so the oil get's changed then."
HOLY SNIKEES Bob ,what motor combination do you run???
Mike
Re: ? many passes ? "running the valves" in your racecar? [Re: mikemotorhead] #369986
07/09/09 12:25 PM
07/09/09 12:25 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Mike
Procharged SBF. Upwards of 2400 HP.
Re: ? many passes ? "running the valves" in your racecar? [Re: BobR] #369987
07/09/09 09:00 PM
07/09/09 09:00 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I work with a guy that runs a big block chevy in PSCA (Hot Street) class. He checks the valves after every run and changes the oil after every race. His motor gets freshened after 70 passes. But the motor sees 9000+RPMs.
Re: ? many passes ? "running the valves" in your racecar? [Re: Darryls-Demon] #369988
07/09/09 09:52 PM
07/09/09 09:52 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I change my oil after 6 to 8 passes and check the valves also..9000 rpm plus..I also run Lucas 0w20 pro stock oil also..
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: ? many passes ? "running the valves" in your racec [Re: FASTFISH420] #369989
07/09/09 10:18 PM
07/09/09 10:18 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I think there's a wide variety of types of motors on this post. Like most things the more power or rpm's the more preventative maintenance. Roller cams will need less checks than solid lifter cams. Some guy's will get more junk in their oil buy pulling the valve covers causing more problems than if they didn't do anything. I change my oil with every oil pan replacement.
Re: ? many passes ? "running the valves" in your racec [Re: rowin4] #369990
07/10/09 06:39 AM
07/10/09 06:39 AM
gregsdart Offline
gregsdart  Offline
It all depends on what setup you run. Stock cam, the valve covers come off when it hits the bone yard. Proven, known solid lifter flat tappet combos, once stabilized, once a year? A radical roller, with aggressive ramps and very high spring pressures, every few passes, or if the car slows any measurable amount. Never had a catastrophic failure (whole engine lost due to valvetrain trouble) but have caught many parts going away, was able to fix and race the rest of the day.
Re: ? many passes ? "running the valves" in your racec [Re: gregsdart] #369991
07/10/09 06:58 AM
07/10/09 06:58 AM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
I run the valves every spring, they haven't changed since I put the inner springs in after break in. Oil gets changed once or twice a year. Dave
Re: ? many passes ? "running the valves" in your racec [Re: gregsdart] #369992
07/10/09 07:55 AM
07/10/09 07:55 AM
Arizona
Chris'sBarracuda Offline
Arizona
Couldn't have said it any better..
Except the oil change.. I guess, when I feel like it..
Chris..
