Re: Chassis dyno numbers: HP loss for 4 sp./Dana?
[Re: Joshs68]
#369619
07/08/09 12:12 AM
07/08/09 12:12 AM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
what was the difference between the corrected and the actual numbers.
Subtract 25% from my posted numbers to get the real numbers...
I ran mine and was not impressed with my #'s. I had a blown intake manifold gasket and was sucking oil on both sides, it was 95* and humid and my car overheated due to the lame fan in front of the car. I need a redo
I'm not disappointed in the numbers; in fact, just the opposite. If driveline loss is 15% and I can come in at 500 HP, the numbers will be right on target. Anything over 500 HP is a bonus...
I modded the bathtub to segregate it from the intake ports. I may develop a vacuum leak (doubtful), but I won't pull in oil.
[Re: 70Cuda383]
#369620
07/08/09 12:19 AM
07/08/09 12:19 AM
64Post
Baltimore/Denver
that's surprising that you didn't have jets big enough for it...you're at 5,000 feet in aurora! there's not as much air up there so you need less fuel anyway!
It came as a surprise to me, too that's why I wasn't prepared. It looks like I'm going to end up with something close to 77/91s. MCH Eddys...
