how do i hault fore and aft movement with elephant ears #369512
07/07/09 08:15 PM
07/07/09 08:15 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
i have a big block A body with elephant ears , no mid plate and a stock trans mount . what would be the best way to stop the motor from moving/? i have an alternater adjuster mounted to the frame and the alternater mounted to the head. i recently riped the mounting tab off the alt. so i know it is moving . i launch 3700 of a brake
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369513
07/07/09 08:36 PM
07/07/09 08:36 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Competition Engineering and S&W race cars make fore-aft limiter kits. One is good, two is better. I mounted our's on the pan rail, but getting a straight shot to the K-member is not that important if running two bars (triangulated to frame) to the back or front of the block. The trans mount in our car was destroyed without a limiter.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Post deleted by Defbob [Re: mcat4321] #369514
07/07/09 08:37 PM
07/07/09 08:37 PM
Re: how do i hault fore and aft movement with elephant #369515
07/07/09 10:54 PM
07/07/09 10:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
He said big block , but i don't think he meant chevy.
Post deleted by Defbob [Re: rowin4] #369516
07/07/09 11:03 PM
07/07/09 11:03 PM
Re: how do i hault fore and aft movement with elephant #369517
07/07/09 11:53 PM
07/07/09 11:53 PM
Northeast, Arkansas
Dodgeman67 Offline
Dodgeman67  Offline
Northeast, Arkansas
We have one on our car and it goes from the block at the midplate to the frame. You can take it from your elephant ears to your frame I imagine or even do it like mine.
I have some pictures somewhere.
Re: how do i hault fore and aft movement with elephant [Re: Dodgeman67] #369518
07/08/09 07:30 AM
07/08/09 07:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the motor mounts on the engine to the frame rail
1 on each side
Re: how do i hault fore and aft movement with elephant [Re: MR_P_BODY] #369519
07/08/09 08:05 AM
07/08/09 08:05 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I have 1/2" thick elephant ears on my elephant / A-Body car . Is fore and aft movement an absolute ? My car`s new in that I haven`t run the new engine combo under full power yet , and this thread`s got me thinkin'.
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: how do i hault fore and aft movement with elephant [Re: chryco] #369520
07/08/09 08:17 AM
07/08/09 08:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chryco
Without limiters it will happen. A flat plate isnt very
good to hold the load/G-force in the direction you are
using it in.... great for vertical loading... but
after time it may end up cracking.... the wider the
spread the ears are the more it moves
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369521
07/08/09 08:52 AM
07/08/09 08:52 AM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
this is the limiter I made for mine, not real pretty but it's under the car out of sight and most important it works. Easy to make and install too
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: how do i hault fore and aft movement with elephant ears [Re: 65dragnet] #369522
07/08/09 09:32 AM
07/08/09 09:32 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
will the transmission ears work? say from the trans to the trans cross member , one on each side
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369523
07/08/09 03:44 PM
07/08/09 03:44 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I hope so. That's what I did!
CrAzYMoPaRGuY
Re: how do i hault fore and aft movement with elephant ears [Re: CrAzYMoPaRGuY] #369524
07/08/09 04:41 PM
07/08/09 04:41 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
thats exactly what i was thinking
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369525
07/08/09 04:54 PM
07/08/09 04:54 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
As I recaal, I wheelhopped my ex-race Chall w/1/4"(?)3/8"? ears once and spit out the water pump hsg to block gaskets.
No fun losing your coolant away from home in a siamese bore block.
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369526
07/08/09 04:54 PM
07/08/09 04:54 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
I built one by making 2 steel tabs, bolt 1 to the ear for the motormount, the other to the bolts holding the ear to the chassis and weld a 1/2" rod to them, you only need 1 and can put it on either side, it also comes out with the motor so it's 1 less thing to remove when doing an R&R.
Re: how do i hault fore and aft movement with elephant ears [Re: mcat4321] #369527
07/08/09 06:04 PM
07/08/09 06:04 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Thanks ! I never thought of going from the trans (Glide) to the crossmember. Gotta get that fabbed right soon . I want to run the car for the first time in August !
Chryco
Re: how do i hault fore and aft movement with elephant ears [Re: chryco] #369528
07/09/09 07:22 AM
07/09/09 07:22 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Done !
Re: how do i hault fore and aft movement with elephant ears [Re: chryco] #369529
07/09/09 09:12 PM
07/09/09 09:12 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Done !
pics?!
