M&H wiring harness's disappointed -Update #369375
07/07/09 06:57 PM
07/07/09 06:57 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
I guess I expected better, since this is supposed to be the best. I ordered all new harnesses for my 71 B project. I just checked two of them tonight and both are not correct when compared to my originals and the wiring diagram. I'm I expecting too much. The harnesess are still functional but in a few years when and if i have to troubleshoot they won't agree with the book.
1. 2 speed wiper motor. In the picture the red and brown wires are switched. The two wires going to the resistor are brown instead of red. And the harness is 3 inches longer than my original. Now the red and brown wire carry properly at the other end so it should work OK.
2. B/U lamp harness. They have a violet wire instead of black. Again this is compared to my originals and the diagrams.
I'm afraid to check the other more complicated ones. I'm gonna call them tomorrow to see what they say. Anyone else notice this???
Re: M&H wiring harness's disappointed [Re: gygeneral] #369376
07/07/09 06:58 PM
07/07/09 06:58 PM
Ont, Canada
Ont, Canada
The other end of the wiper motor
Re: M&H wiring harness's disappointed [Re: gygeneral] #369377
07/07/09 07:04 PM
07/07/09 07:04 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
M&H makes the most accurate and likely the most reliable reproduction harnesses on the market. No, they are not perfect. Sometimes thier mistakes can be fixed by modifying them to match your original harnesses.
If you expect perfection you'll need to find NOS harnesses, not the easiest task these days, in some cases it's simply impossible as they don't exist. Some will say that NOS are no better than used, but in my experieince I have never found a bad one that's been in dry storage in original packaging.
Re: M&H wiring harness's disappointed [Re: gygeneral] #369378
07/07/09 07:06 PM
07/07/09 07:06 PM
Montreal,Quebec,Canada
JulesdaWiperman Offline
super gas
super gas
"2 speed wiper motor. In the picture the blue and brown wires are switched."
Actually it is the red and the brown wires that are reversed. Make sure you correct that.
Concerning the brown wires versus the red. Brown wires were used until late 70s and then they used red.
I am sure M&H only offers one type just to save costs.
Jules
Re: M&H wiring harness's disappointed [Re: JulesdaWiperman] #369379
07/07/09 07:35 PM
07/07/09 07:35 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
71 Challenger Wiring Diagram
Re: M&H wiring harness's disappointed [Re: Snoopy] #369380
07/07/09 07:59 PM
07/07/09 07:59 PM
Ont, Canada
Ont, Canada
"Actually it is the red and the brown wires that are reversed"
Jules - Correct, my mistake in colours, I will correct. Didn't know they actually switched colours when its basically the same part. I will still call them and see what they offer as an explanation.
Snoopy, that's the same diagram I'm looking at and my old part matches that. Thanks
As always, live and learn when playing with this stuff. Thanks, now on to the other harnesses.
Re: M&H wiring harness's disappointed [Re: gygeneral] #369381
07/07/09 08:07 PM
07/07/09 08:07 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
I appreciate you posting this. I didn't even think to look at the wiring, I just looked at the connectors. I'll double check mine as well.
Joe
65 Barracuda
70 Challenger
Re: M&H wiring harness's disappointed [Re: jrwoodjoe] #369382
07/07/09 08:29 PM
07/07/09 08:29 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Guys, make sure you check any harness.
A friend just got one for his 71 RR clone, and they had some bad stuff mixed up! If it had not been checked, it would have caused bad things. I'd never heard of such issues, and would not have thought of having to do this, but now I will!
I don't know who did his, so this is not directed to any company in particular.
Re: M&H wiring harness's disappointed [Re: RodStRace] #369383
07/07/09 08:54 PM
07/07/09 08:54 PM
Snoopy Offline
Snoopy  Offline
Better safe than sorry.
Re: M&H wiring harness's disappointed [Re: gygeneral] #369384
07/07/09 11:16 PM
07/07/09 11:16 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
Funny how there was a post a while back where people were bashing Evans wiring and a few guys were talking about how great M&H was. Not saying there bad, but as said before every one can have a slip up now and then. Sorry to hear about your wiring. At least you had the brains to check it out first. The stuff I got from Evans was good and it was pretty inexpensive, so I will keep returning the business till they change my mind.
Re: M&H wiring harness's disappointed [Re: ScottSmith_Harms] #369385
07/08/09 12:14 AM
07/08/09 12:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I did have a 71 B body NOS dash harness in the package, that was found after install to have been "assembled/wired" incorrectly by the "vendor"....it was later corrected using a factory manual......NOS isn't perfect either, M&H makes some rather nice harnesses, and I sure they make mistakes as well,.....I'd rather trust a M&H "new" harness, even if it needs correction, than an old 30-40 year old harness/wiring,....seen too many people lose cars to electrical fires over the years than I care to remember
Re: M&H wiring harness's disappointed [Re: DAYCLONA] #369386
07/08/09 01:16 AM
07/08/09 01:16 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
So have I, which is why I am an advocate of replacing all original used wiring when doing a restoration even if it "appears" to be in mint used condition, but I've never seen a newly installed NOS harness fail or cause any problems, only old original used ones.
Personally I don't think you'll have anymore issues with an unused NOS harness than you would with a brand new reproduction (regardless of the vendor). It's a non issue anyway since finding complete nose to tail NOS wire harnesses set these days is almost an impossibility.
Re: M&H wiring harness's disappointed [Re: ScottSmith_Harms] #369387
07/08/09 09:18 AM
07/08/09 09:18 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I'd call M&H directly (not Year One) and speak with Tom. He is very passionate about the products, a real car guy, and when I had questions on their harnesses I bought a few years ago for my 69 R/T he was top-notch to speak to.
He seemed very interested to know if there was any issue with quality or accuracy.
Darren
Re: M&H wiring harness's disappointed [Re: Ludington1] #369388
07/08/09 09:19 AM
07/08/09 09:19 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Darren
Oh yeah... and then come back and report on your experience, GOOD or BAD!
Re: M&H wiring harness's disappointed [Re: Ludington1] #369389
07/10/09 02:14 AM
07/10/09 02:14 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Any updates after that phone call?
Re: M&H wiring harness's disappointed [Re: Ludington1] #369390
07/10/09 08:17 AM
07/10/09 08:17 AM
Ont, Canada
Ont, Canada
I'm calling next week, I just checked my engine harness and backup light harness yesterday. So now I have all of my data ready. Later
Re: M&H wiring harness's disappointed [Re: Ludington1] #369391
07/10/09 05:42 PM
07/10/09 05:42 PM
Darren
when a few years ago i bought a tach harness for my a12 superbee,when it came in it was too short, it was for the standard nonralleye dash, but the ralleye dash tach is on the far left and standard dash is on far right,
M & H made it right, and sent out a new one right away, they are good guys.
Re: M&H wiring harness's disappointed [Re: Ludington1] #369392
07/13/09 04:43 PM
07/13/09 04:43 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Darren
I could not agree more. If there was a production problem, he will want to know. Let us know what he says.
Good luck,
Randy
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: M&H wiring harness's disappointed [Re: Ludington1] #369393
07/13/09 05:26 PM
07/13/09 05:26 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Norm, you need to speak to TOM! He has helped me out with a few wiring issues. He's a GOOD GUY!
Re: M&H wiring harness's disappointed -Updated [Re: rayztoy] #369394
07/14/09 07:48 PM
07/14/09 07:48 PM
Ont, Canada
Ont, Canada
Well, thanks everyone for giving me Tom's name at M&H. We spoke today for 1.5 hours and he took the time to go over my findings one by one. He also offered to make things right on each one of those findings. What a great experience, and he was very interested and curious on why the differences occured.
How it was left is that I send him my originals and the new harnesses with a note and he will look after getting the new ones back to me.
Some of the differences was due to a manufacturing hickup, some the harness agreed with the engineering drawings but as you all know in the Mopar world things aren't always as they seem and some he must investigate more.
In case you read this Tom, thanks again, it was a learning experience.
Norm
