Torqing ARP head bolts w/o moly lube?? #368289
07/06/09 03:48 PM
07/06/09 03:48 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
I'm trying to torq down a set of 440source heads, their instructions say to go to 60ft-lbs, however I don't have the ARP lube. How tight should I go with just 30w motor oil? The back of the box says I should be in the high 70's but curious if anyone else has done it w/o their moly lube.
Re: Torqing ARP head bolts w/o moly lube?? [Re: DaytonaTurbo] #368290
07/06/09 04:27 PM
07/06/09 04:27 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Why not go get some moly lube?
Re: Torqing ARP head bolts w/o moly lube?? [Re: Challenger 1] #368291
07/06/09 04:29 PM
07/06/09 04:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
With stock heads ARP says to go from 90lbs with moly to 130 lbs with oil. So I would think you will need to up the torque to what ARP suggests.
Re: Torqing ARP head bolts w/o moly lube?? [Re: stumpy] #368292
07/06/09 06:24 PM
07/06/09 06:24 PM
Haysville, Kansas
rdrmod6 Offline
rdrmod6  Offline
Haysville, Kansas
I am curious about this also. When I went to the speed shop to get the ARP grease they said to just use any moly grease. Sixty ft lbs seems a little light but thats what I will do unless I find out something different.
Re: Torqing ARP head bolts w/o moly lube?? [Re: Challenger 1] #368293
07/07/09 12:01 AM
07/07/09 12:01 AM
Manitoba, Canada
Manitoba, Canada
I checked around and nobody around here carries the ARP moly lube(gave me the 'deer in the headlights look' and said they have regular engine assy lube) and the instructions with the ARP bolts say to use only their brand lube, and if you can't get their brand lube to use 30w oil but to a higher torq rating. I don't want to have problems from not following their instructions and I want to bolt these heads on tomorrow, not a week from now by the time the lube gets here if I order it online.
Re: Torqing ARP head bolts w/o moly lube?? [Re: DaytonaTurbo] #368294
07/07/09 06:41 AM
07/07/09 06:41 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
The ARP web site has torque specs for motor oil as well as moly.
Re: Torqing ARP head bolts w/o moly lube?? [Re: bobby66] #368295
07/07/09 08:27 AM
07/07/09 08:27 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
use the oil and do it to that spec
